ipisoft.com
https://forum.ipisoft.com/
Dual Kinect Setup Cameras not positioning correctly on Calib
https://forum.ipisoft.com/viewtopic.php?f=2&t=7009
Page 1 of 1
Author:  CManson [ Fri Mar 22, 2013 1:31 pm ]
Post subject:  Dual Kinect Setup Cameras not positioning correctly on Calib
Have the 2 Kinects set at about 160 degrees
Worked fine before, but today went and started working with new update and new Calibration keeps positioning the cameras like they were on the same side of the room.
Have moved cameras, done several new test Calibrations, same thing over and over.
Author:  vmaslov [ Sat Mar 23, 2013 12:59 am ]
Post subject:  Re: Dual Kinect Setup Cameras not positioning correctly on C
With automatic detection of dual Kinect setup's angle you should give more move to calibration board: forward and backward, side to side. 1m move to each direction should be sufficient.
Author:  Greenlaw [ Sat Mar 23, 2013 1:43 am ]
I was just about to comment but vmaslov beat me to it. :)
Yes, you introduce back and forth motions to your calibration pattern--this makes it clear to Mocap Studio which configuration you're calibrating for. I only move my board about half a meter towards the Kinects and it works fine but this probably depends on distance from and angle of the Kinects.
Author:  CManson [ Sat Mar 23, 2013 8:41 am ]
Thanks guys!
Will give it more movement.
Author:  mitchfx [ Mon Jul 15, 2013 9:51 pm ]
I have the same problem often every since you guys removed the Kinect config type options and went to "auto detect" method. How about adding a way for the user to manually force the type of setup when needed? It's not like it was that much work to begin with (one button click)...and it ALWAYS worked :)
http://www.phpbb.com/
