It is currently Mon Nov 09, 2026 1:49 am
 Post subject: Kinect 2
PostPosted: Sat May 04, 2013 12:24 pm
Kinect 2 will have higher resolution nearly x2. ipi team, do you expect double precision results? can i combine kinect 360 and kinect 2 when available?
KINECT 2 SPECS
Field of View: 70? horizontal by 60? vertical
Resolvable Depth: 0.8 m -> 4.0 m
Colour Stream: 1920 x 1080 x 16 bpp 16:9 YUY2 @ 30 fps
Depth Stream: 512 x 424 x 16 bpp, 13-bit depth
Infrared Stream: 512 x 424, 11-bit dynamic range
Registration: Colour <-> depth and active IR
Audio Capture: 4-mic array returning 48K Hz audio
Data Path: USB 3.0
Latency: ~60 ms with processing
Tilt Motor: No tilt motor
ORIGINAL KINECT SPECS
Field of View: 57.5? horizontal by 43.5? vertical
Colour Stream: 640 x 480 x 24 bpp 4:3 RGB @ 30fps640 x 480 x 16 bpp 4:3 YUV @ 15fps
Depth Stream: 320 x 240 16 bpp, 13-bit depth
Infrared Stream: No IR stream
Registration: Color <-> depth
Audio Capture: 4-mic array returning 48 Hz audio
Data Path: USB 2.0
Latency: ~90 ms with processing
Tilt Motor: Vertical only
 Post subject: Re: Kinect 2
PostPosted: Sat May 04, 2013 2:40 pm
The accuracy may improve slightly, but not dramatic.
It is too early to talk about what configurations could be used with new Kinect. First we get the device, then think about the ways it can be used.
