| Kinect 2 https://forum.ipisoft.com/viewtopic.php?f=2&t=7521 |
| Author: | atmuc [ Sat May 04, 2013 12:24 pm ] |
| Post subject: | Kinect 2 |
Kinect 2 will have higher resolution nearly x2. ipi team, do you expect double precision results? can i combine kinect 360 and kinect 2 when available? KINECT 2 SPECS Field of View: 70? horizontal by 60? vertical Resolvable Depth: 0.8 m -> 4.0 m Colour Stream: 1920 x 1080 x 16 bpp 16:9 YUY2 @ 30 fps Depth Stream: 512 x 424 x 16 bpp, 13-bit depth Infrared Stream: 512 x 424, 11-bit dynamic range Registration: Colour <-> depth and active IR Audio Capture: 4-mic array returning 48K Hz audio Data Path: USB 3.0 Latency: ~60 ms with processing Tilt Motor: No tilt motor ORIGINAL KINECT SPECS Field of View: 57.5? horizontal by 43.5? vertical Resolvable Depth: 0.8 m -> 4.0 m Colour Stream: 640 x 480 x 24 bpp 4:3 RGB @ 30fps640 x 480 x 16 bpp 4:3 YUV @ 15fps Depth Stream: 320 x 240 16 bpp, 13-bit depth Infrared Stream: No IR stream Registration: Color <-> depth Audio Capture: 4-mic array returning 48 Hz audio Data Path: USB 2.0 Latency: ~90 ms with processing Tilt Motor: Vertical only |
| Author: | vmaslov [ Sat May 04, 2013 2:40 pm ] |
| Post subject: | Re: Kinect 2 |
The accuracy may improve slightly, but not dramatic. It is too early to talk about what configurations could be used with new Kinect. First we get the device, then think about the ways it can be used. |
