| IPI recorder buffering https://forum.ipisoft.com/viewtopic.php?f=2&t=8452 |
| Author: | Danakinobi [ Thu Aug 15, 2013 11:11 pm ] |
| Post subject: | IPI recorder buffering |
I'm trying out the IPI recorder for the first time. I noticed it only allows for about two minutes of footage and then it tries to buffer. I often get an error unless I stop it before it reaches the maximum buffer. Is there a setting for this? Or a way to control when it buffers? |
| Author: | djtaylor [ Fri Aug 16, 2013 6:42 am ] |
| Post subject: | Re: IPI recorder buffering |
That sounds like your hardware isn't able to keep up. Look towards that area or record to SSD as possibly a quick fix. |
| Author: | Greenlaw [ Fri Aug 16, 2013 11:42 pm ] |
+1 on the SSD. Installing an SSD dedicated for capture made a huge difference in improving data flow for my system--never a dropped frame now. G. |
| Author: | vmaslov [ Sat Aug 17, 2013 12:57 pm ] |
iPi Recorder always buffers while recording. You should watch that buffer is not overflowed (in normal conditions it always looks empty). Buffer overflow signals that some component of recording pipeline is not powerful enough - either CPU (gathering and encoding camera data) or disk (writing the data). You can also use a RAM drive as a cheap alternative (with less size) to SSD suggested above. |
| Author: | Danakinobi [ Tue Aug 20, 2013 1:25 pm ] |
OK... It may be my laptop HD is just too slow... I'll perhaps try three cameras instead of four and then see what results I get. Also try an external HD too. |
