ipisoft.com
https://forum.ipisoft.com/
Pair PS Move with iPi Recorder
https://forum.ipisoft.com/viewtopic.php?f=2&t=8860
Page 1 of 1
Author:  mborish [ Wed Oct 16, 2013 8:29 am ]
Post subject:  Pair PS Move with iPi Recorder
Hello,
I'm trying to pair the PS Move with iPi Recorder. I have already been using it with a Kinect and I'd like to try some head orientation capture. However, I can't get past the screen where iPi Recorder says to plug in the PS Move via USB. It just hangs on this screen. This is a Win7 machine so I shouldn't need the Motion in Joy drivers right? I have my bluetooth setup, and the rest of the pairing process should be through the Recorder shouldn't it? I've attached my trace from the step where it hangs. Thanks for any help.
trace_20131016_112021.txt.gz [14.7 KiB]
Downloaded 727 times
Author:  vmaslov [ Thu Oct 17, 2013 4:36 am ]
Post subject:  Re: Pair PS Move with iPi Recorder
Hello
So, what is happening exactly? You connect PS Move via USB and nothing changes, the program still requests an USB connection?
In case you have not seen it already, you can find useful this video of pairing procedure:
http://vimeo.com/bassill/pairing-ps-move-in-recorder
And yes, you should not need Motion in Joy drivers to connect PS Move on Win 7.
http://www.phpbb.com/
