| YUY2 Format at 60 FPS at 640x480 resolution? https://forum.ipisoft.com/viewtopic.php?f=2&t=8883 |
| Author: | mikeanon [ Tue Nov 19, 2013 4:29 pm ] |
| Post subject: | YUY2 Format at 60 FPS at 640x480 resolution? |
Trying to use the PS3 Eye cameras at 60 FPS at 640x480 resolution in YUY2 format causes them to drop 50%+ frames and be unusable, but it works at 30 FPS or 60 FPS @ 320x240 resolution. I am using iPi Recorder 1.x. Is this a known issue - just too much bandwidth or issues with bulk sending of data? |
| Author: | vmaslov [ Tue Nov 19, 2013 10:54 pm ] |
| Post subject: | Re: YUY2 Format at 60 FPS at 640x480 resolution? |
Do you mean that issue is only when recording in YUY2 format, and Bayer format at 640x480@60 is OK? If so, than yes, it is likely a bandwidth issue - either with USB or with HDD. Bayer format is less space consuming. |
