 Post subject: Working USB CONTROLLER
PostPosted: Thu Nov 21, 2013 10:34 am
Hello
First let me start by say how great and exciting it is to be working with this software.
We have done some tests however we want to setup 6 play station eye cameras.
I have found alot of information about what usb controllers don't work.
USB 2 NEC and USB 2 HUB ones
and
also
USB 3 NEC and the VIA one.
If any can or could confirm if any of the following work that would be great.
i have the following setup
http://support.asus.com/download.aspx?S ... 2co6Q5v0BZ
motherboard
i7 920
580 nivida
and 6 playstation eye cams
and a samsung eve 120 ssd
plus a 1 T hard drive.
the following cards are the quickest for me to source, from maplin (i live in the uk)
http://www.maplin.co.uk/usb-2.0-1-inter ... ard-221506
http://www.maplin.co.uk/usb-2.0-5-port- ... ard-228619
http://www.maplin.co.uk/usb-3.0-pci-e-adaptor-858272
http://www.maplin.co.uk/us-robotics-2-p ... ard-814659
thank you in advance for any help you give
matt
PostPosted: Fri Nov 22, 2013 3:20 am
All known to us USB compatibility issues are listed at the bottom of http://wiki.ipisoft.com/USB_controllers#Known_compatibility_issues.
As I see from the specs of your mainboard (ASUS PT6 Deluxe), it has only two Intel USB 2.0 controllers integrated in chipset. So, to work with 6 PS Eye cams you need 1 additional USB controller.
The last 2 ones from your links look like based on NEC USB3 chipset (from the photo, there is no chipset details in text description) which works smootly with PS Eye cameras. So I can recommend one of these cards.
PostPosted: Fri Nov 22, 2013 4:21 am
thanks i'll look at these in the shop and give one a go.
It is hard as a new IT guy to work out the best one because almost everywhere in the UK, (online) the usb cards do not list the controllers in the description.
PostPosted: Fri Nov 22, 2013 9:40 am
You can try to find out the used chipset on the manufacturer's website looking by controller's part number. For example, StarTech controllers are offered by many UK online stores (including Amazon.co.uk), and they have chipset info for each controller.
PostPosted: Thu Nov 28, 2013 4:03 am
Hello
Thanks for the help.
Unfortunatly not all web sites are very forward giving the usb controller information.
We have set it up for a small test today and it works.
I went with this one. It worked for me in my machine posted above.
http://www.amazon.com/Transcend-Adapter ... B003MVJG8Q
(got it from maplin, stocked in there larger stores)
You have to download drivers from site, i used the sata power connector
and install these drivers
http://www.transcend-info.com/Support/D ... ID=TS-PDU3
hope this helps
thanks
Matthew
(Well post but if i have any frame drops etc with this setup)
