 Post subject: Advice needed
PostPosted: Thu Jan 30, 2014 5:19 am
Hi all,
I need to do some motion capture for a scene where the character is lying down on her front on a bed, talking on the phone.
I'm using a 2xKinect setup.
Has anyone out there successfully (or unsuccessfully) done this?
I'm not sure if I should move from a T-pose and get into that position lying on the floor, or do I go from the T-pose, and lie on a plynth (or a row of stools?) on set so my body is raised from the floor to minimise occlusion errors.
Any help would be greatly appreciated. Thanks for reading!
Paul
File comment: I've attached a picture to this post to show the pose
 Post subject: Re: Advice needed
PostPosted: Thu Jan 30, 2014 4:47 pm
The biggest challenge here would be self-occlusion, especially the arm hidden under the subject. I would expect to kill the keyframes for that arm and animate it manually after you've tracked the rest of the body.
In general, you'll need to position the cameras strategically to capture as much of the visible body as possible. If you were using PS Eye cameras, you would position a couple of cameras very high and some very low. Seeing you have dual Kinect, you might try one higher up and the other just a little lower than normal, favoring positions with the most visibility. Don't go too extreme though--as you many know, you don't have as much flexibility when positioning Kinect devices as you do with PS Eye cameras.
If the actor needs to do more than maintain that position, like rolling in bed while talking, that gets more complicated. If this is for a film project with camera angles that cut from shot to shot, try to edit around the motions because it will be easier to capture these motions in separate takes.
Another thing to consider: avoid shooting in an actual bed as this may cause even more occlusion problems. If the actor isn't moving around too much, consider shooting with the performer on a long bench with a firm surface or padding. If the surface is too soft (like a mattress,) the performer may sink into it, causing even more occlusion problems. If a bench or appropriate furniture isn't available, consider raised platform you can move around. The point is to keep off the floor because the system will clip any data an inch or two from the floor. (It's an issue with Kinect only.)
If you use a bench or platform, calibrate your setup before putting it into the scene. Then, when you're ready for motion capture, add the items but also be sure you run a Scene Evaluation to subtract the furniture.
Starting from a T-Pose helps as it gives you a starting point that can lead into the pose you want, even it it doesn't go 100% into the intended pose. More than likely, you'll need to adjust the body once it's near the intended pose. Since this is a complicated pose for Kinect capture, I would definitely experiment with this pose before going into an actual shoot--you may need to adapt the pose to favor what's actually trackable with Mocap Studio.
I haven't done exactly the example you've shown in the photo but based on what I have shot in the past, I think that should do it. Hopefully somebody with experience in shooting this pose will pop in with proven tips.
Good luck.
PostPosted: Tue Feb 04, 2014 5:34 am
Hi Greenlaw, thanks for the tips. Most of the things you said I have already considered so I know I'm most likely going to get a decent result.
I'll have to look into how to kill the keyframes for specfic limbs, but the rest should be do-able. I'll let you know how it goes and maybe post a wireframe mp4 on here at some point soon.
Thanks again.
PostPosted: Mon Feb 17, 2014 1:21 pm
I'd probably get my actor to do a face down tpose on the bed, then an assistant can slip the pillow in for the shot.
PostPosted: Tue May 06, 2014 1:32 pm
Hi all, I've had this mocap done for a while now, but I thought I would post a short clip of the finished mobcap.
I got a pretty good result, using my son's toy box as a plinth. Hurt like hell on the old elbows, but hey, I got it done. Thanks everyone for their advice, I appreciate it.
Here's the clip - https://www.youtube.com/watch?v=uEoSpLebQfg&feature=youtu.be
