Laptop hardware suggestions for portable capture
https://forum.ipisoft.com/viewtopic.php?f=2&t=9137
Author:  redfox3d [ Sun Aug 24, 2014 4:48 am ]
Post subject:  Laptop hardware suggestions for portable capture
I want to be able to setup and capture data at various locations. I'm looking at investing in a laptop for portability but concerned with the usb bandwidth if these will suffice for a 6 or 8 camera setup. Any advice is appreciated:
MSI WS60 "workstation" laptop:
This is my first choice and has 3 3.0 usb ports.. will that be enough?
http://www.newegg.com/Product/Product.a ... 6834152618
DELL XPS M1710 (used):
Cheap used gaming laptop that has 6 2.0 usb ports!
http://www.ebay.com/itm/DELL-XPS-M1710- ... 4897.l5665
http://www.notebookreview.com/notebookr ... ics-specs/
SURFACE PRO 3:
Probably a long shot, but I thought about a surface pro 3 with a docking station (3 3.0 usb and 2 2.0 usb ports).
Surface Pro 3 tablet
http://www.frys.com/product/8115965?sit ... IN_RSLT_PG
Docking Station
http://www.frys.com/product/8142515?sit ... IN_RSLT_PG
Author:  vmaslov [ Sat Aug 30, 2014 8:31 am ]
Post subject:  Re: Laptop hardware suggestions for portable capture
Hello
If you plan to use a laptop with 6-8 cameras configuration, then you are in a big trouble. As you should know, the main thing for many cameras is the number of USB controllers (not even ports).
We used to connect 6 cameras to DELL Alienware M17x laptop, which has 3 USB 2.0 ports (2 controllers) and 2 USB 3.0 ports (1 controller), with USB hub to extend the number of the ports. Unfortunately, modern laptops tend to have only USB 3.0 ports, so only a single USB controller is exposed. Also, an ExpressCard slot has become an ancient thing, so adding an external USB controller is not an option now.
You should choose a laptop which has both USB 3.0 and USB 2.0 ports which guarantees you at least 2 USB controllers (4 cameras at 60 fps or 6 cameras at 40-50fps).
In v3, we plan to add the support for distributed recording. That will allow to cope with resource limits of a single laptop by using a couple of them.
