PostPosted: Tue Nov 25, 2014 1:54 pm
This has got to be the number one time killer when tracking my mocap data. The shoulders ALWAYS try to turn inward while solving! I have to babysit the tracking progress and pause every few frames to re-rotate the shoulder to a natural position. It's very frustrating.
Has anyone else encountered this issue? Is there a way I can tell the software that "hey, it isn't natural to touch the back of your hand to your waist"?!!!
PostPosted: Wed Nov 26, 2014 5:44 am
Is this color or depth video?
I suppose it's color, and you just need to adjust actor colors and/or scene lighting better. Or make the lighting in mocap area more ambient in case there are harsh shadows in the video.
Please share your project and video to get more specific recommendations. You can use file sharing services for big files.
PostPosted: Wed Nov 26, 2014 2:33 pm
Thanks for the quick reply!
This problem is happening when tracking from the depth video (I have not tried tracking color video yet). The shoulders just seem to default to an inward rotation which always results in bad tracking that constantly loses the lower arm when the elbow rotates. For our recording session we used two xBox Kinect cameras set slightly off 180° from each other (full 180° caused weird flickering) and placed drop cloths in front of the walls to minimize the no depth (yellow) data points.
I've attached a zip file for the iPi project and calibration scene for one of the shots I am currently working on, but this issue seems to happen with all of the mocap tracking of our data in iPiStudio. Please let me know if you need any other files to view the project. We recorded in 2-3 minute long takes so the original data files are pretty large (3GB+).
Any tips you can provide would be really helpful. I appreciate it!
screenshot from frame 2050 of the project
File comment: iPi project file and calibration file for SarahDance005_tracking
SarahDance005_tracking.zip [2.43 MiB]
Downloaded 830 times
PostPosted: Sun Nov 30, 2014 1:38 am
Please provide the iPiVideo record for that project (using some file-sharing service like Drop Box or Google Drive).
Tip. You could use compression options in iPi Recorder to reduce record sizes (see COMPRESSION group on RECORD tab).
PostPosted: Mon Dec 01, 2014 9:44 am
I've uploaded the ipiVideo to Google Drive. You can access the file here:
https://drive.google.com/file/d/0B4yncG ... sp=sharing
PostPosted: Mon Dec 01, 2014 9:53 am
Thanks. I'll check it and get back to you with feedback.
PostPosted: Tue Dec 02, 2014 7:42 am
I have looked at your video.
Unfortunately, there is no straightforward way to fight this problem. The error comes from the nature of optical tracking - it is hard to determine the rotation of arm's joints when it's almost straight. So there is a need to apply some heuristics to define what we can't see. And in this case it tends to default joint rotation (as in T-pose).
In V3, we are working to improve these heuristics to make a motion more continuous and natural. Though this work is not complete yet, I encourage you to try V3 on your projects. It already produces far less tracking errors than V2, so less need for clean up.
Also, I have a few general recommendations based on your video:
  • When tracking dancing motions, try tracking options Shoulder positions tracked from video and Very flexible spine. They may produce more desirable results.
  • When using depth sensors, wearing boots with reasonably thick sole improves the accuracy of feet tracking.
  • Wearing a bit tighter pants may improve tracking. Such pants as in this video hide minor movements in hip and knee joints.
PostPosted: Tue Dec 02, 2014 10:12 am
I had thought that the shoulder issue might be inherent in the way the software tracks the depth information, it's just challenging because it always seems to prefer rotating the shoulders inward.
Thank you for looking into this, vmaslov. I really appreciate all of your help! Those extra tips will definitely help for our next recording session as well. I'm also excited to hear that you are working on a V3 and I would definitely like to try it out. Do you know where I can find a download for this version?
EDIT: I just found the download for version 3. Here's the link for anyone else:
http://docs.ipisoft.com/iPi_Mocap_Studi ... _3.0.2.171
Users browsing this forum: Google [Bot] and 69 guests
