It is currently Mon Nov 09, 2026 2:47 am
PostPosted: Mon Nov 10, 2014 1:26 pm
I'm using the iPi 3 software with the Kinect 2 camera type software/hardware installed.
When I run the iPi Recorder, my Kinect 2 shows up but is unaccessible. It has the red warning that says it is "not available" and being a device in error state it can not be used.
Anyone know how to fix this?
Thanks in advance!
PostPosted: Tue Nov 11, 2014 3:38 am
Hello aforetaste,
Please, try the following steps:
  • First of all, make sure that Kinect 2 is connected to PC and is connected to AC/DC adapter, and adapter is plugged to power.
  • Try to connect Kinect 2 to different USB 3.0 port.
  • Try to reboot.
PostPosted: Tue Nov 11, 2014 8:11 am
Thank you, Andrew.
By connecting the Kinect 2 to a different usb 3.0 port that did the trick with the "in error state."
On another note: you can't seem to mix a Kinect 2 along with a Kinect 1. Is that true?
Many thanks!
PostPosted: Tue Nov 11, 2014 2:42 pm
Yes, unfortunately. They cannot be mixed due to incompatible video modes and different FOVs.
PostPosted: Thu Mar 12, 2015 4:00 pm
Hi all, I am facing the same problem.
device is in error state and cannot be used,
I have checked everything required but still it is giving this issue .
can any one please help me .
Users browsing this forum: No registered users and 111 guests
