Asynchronous read from pipe has filed with usb3.0 controller
https://forum.ipisoft.com/viewtopic.php?f=2&t=9556
Author:  HardRender [ Mon Apr 18, 2016 8:38 am ]
Post subject:  Asynchronous read from pipe has filed with usb3.0 controller
Hi. Got this message, when I try to connect two PS Eye cameras in one usb 3.0 controller.
PC Adapter 750 w
MotherBoard
970AUD3P
8 usb 2.0
2 Usb 3.0
Why? Thnx for hlp
Author:  vmaslov [ Tue Apr 19, 2016 2:37 am ]
Post subject:  Re: Asynchronous read from pipe has filed with usb3.0 contro
I suppose this is a compatibility issue between cameras and USB controller.
According to motherboard's specs, it has VIA VL805 USB 3.0 controller. And PS Eye has known problems with VIA VL800 controller. So I think similar problems may remain in this newer version of VIA controller.
I recommend you to install USB 3.0 extension card based on NEC chipset (µPD72020x series).
Author:  HardRender [ Tue Apr 19, 2016 11:20 am ]
Ok. Thanks. It was just cable trouble.
And by the way, where I can know about USB chipset of any controller?
Author:  vmaslov [ Wed Apr 20, 2016 12:55 am ]
USB chip name can usually be found in specification of motherboard or USB controller extension card. And product specs can usually be found on manufacturer's website.
