It is currently Sun Nov 08, 2026 11:29 pm
PostPosted: Tue Aug 30, 2016 10:14 am
Hi, i'm a little confused by the instructions in the ipisoft docs for scene scale. It says to use cam 1 ground to height to adjust the scene scale however if you move the scale slider the cam 1 ground to height adjusts as well. So theres no constant to adjust to. Is this measurement taken manually? If the scale adjusts cam 1 as well, what exactly are you adjusting it to?
PostPosted: Tue Aug 30, 2016 2:19 pm
Yes, you should measure something by hand in the real world. Once you have the measurement - say, actual height of camera #1 - then you can adjust the scene scale so that the height value displayed in the program matches real world.
Users browsing this forum: No registered users and 56 guests
