Confused about scene scale/cam 1 ground to height
https://forum.ipisoft.com/viewtopic.php?f=2&t=9614
Author:  chaywood [ Tue Aug 30, 2016 10:14 am ]
Post subject:  Confused about scene scale/cam 1 ground to height
Hi, i'm a little confused by the instructions in the ipisoft docs for scene scale. It says to use cam 1 ground to height to adjust the scene scale however if you move the scale slider the cam 1 ground to height adjusts as well. So theres no constant to adjust to. Is this measurement taken manually? If the scale adjusts cam 1 as well, what exactly are you adjusting it to?
Author:  vmaslov [ Tue Aug 30, 2016 2:19 pm ]
Post subject:  Re: Confused about scene scale/cam 1 ground to height
Yes, you should measure something by hand in the real world. Once you have the measurement - say, actual height of camera #1 - then you can adjust the scene scale so that the height value displayed in the program matches real world.
