 Post subject: Ps3 Move Connection
PostPosted: Thu Apr 20, 2017 12:33 pm
Can you tell me. Is it possible to connetion ps3 move controller to pc in 2017 ? I can not find normal tutorial.
Tried Ds3 (not workin
Scp (not working)
PSMoveConfigTool (not working)
i bought all important items for work but it still does not work....
(USB Adapter bt400 asus , Move controller , 3 camers sony ps3)
What i have to do ?
 Post subject: Re: Ps3 Move Connection
PostPosted: Thu Apr 20, 2017 2:18 pm
Have you tried pairing procedure for PS Move in iPi Recorder yet?
http://docs.ipisoft.com/Motion_Controllers#Recording
PostPosted: Fri Apr 21, 2017 3:47 am
Ofc. The program does not see any controllers to pairing..
(i have...ON Bluetooth and connected with USB cable).
it is disheartening! :(
PostPosted: Fri Apr 21, 2017 4:22 am
At which exact stage of pairing procedure you're stuck? When it's searching for BT adapters, when it asks to connect PS Move via USB, after you disconnect PS Move from USB?
What's your OS?
You've noted that you have tried DS3 tool for pairing. Did you roll back drivers for BT adapter and PS Move after using DS3?
PostPosted: Fri Apr 21, 2017 5:31 am
The Problem was USB cable with another cable everything working. Thanks for fast answer and help me.
PS. I do not recommend cheap cables ....
