It is currently Sun Nov 08, 2026 4:51 pm
PostPosted: Tue Oct 03, 2017 10:01 pm
If I have 3 computers running 12 ps3 cams do all the computers need a Bluetooth adaptor for the move controller tracking?
Also, can I i use 3 computers GPU (link the GPUs together) at the same time?
https://t.me/pump_upp
PostPosted: Wed Oct 04, 2017 1:15 am
The number of Bluetooth adapters needed depends on the number of PS Moves used. Usually one Bluetooth adapter can handle up to 4 PS Moves. So if you track one actor then one Bluetooth adapter is sufficient. If you track two actors with 3 PS Moves per each then it's probably the best option to split them between 2 BT adapters connected to different PCs.
You can utilize for tracking multiple GPUs in the same PC. But distributed tracking with several PCs is not supported.
