Delete Tracked Frames?
https://forum.ipisoft.com/viewtopic.php?f=4&t=1647
Author:  TheOwl [ Sun Feb 07, 2010 12:08 am ]
Post subject:  Delete Tracked Frames?
1.) In my experience in tracking in DMC, there is always an arm or both that is not tracked successfully resulting the arm poke through the head or body even if I do a Hi-Res Tracking.
Because of this I locate the frame which the incorrect track started and manually correct them using IKs and Rotate and do the same at the rest of the mistracked frames.
Its a time consuming process but its alright with me. I think its a necessary work due to the software's limitations.
But it becomes a little difficult to do for after finishing manually correcting one frame, the next unedited frame turns to its originally tracked pose. If I can delete a set of frames which every unedited frame copies the last pose that was edited and will not affect the correctly tracked frames, it will going to be much easier.
Author:  skin12002 [ Mon Feb 22, 2010 4:27 am ]
Post subject:  Re: Delete Tracked Frames?
Hi Owl
I would like to add my vote for this as well
cheers
Steve Skinner
