It is currently Sun Nov 08, 2026 2:12 pm
 Post subject: Hold last tracked pose
PostPosted: Mon Feb 22, 2010 4:46 am
Hi All
First of all i'd like to say what a fantastic piece of work this software is
I think what you have done is nothing short of amazing!!
Would it be possible to have the last frame tracked to be held
So if you pose your figure that pose will be held until the next frame is tracked and so on
Then if you scrub past the last tracked frame, the figure does not jump back to the default tee pose
I have had situations where I have posed a figure at the start of a sequence and then realiased that I had set the range of interest start point one or two frames ahead of the pose frame and as the software tracks forward the figure jumps back to the default position and the tracking fails
Hope that makes sense
Cheers
Steve Skinner
PostPosted: Tue Feb 23, 2010 2:21 pm
Sorry man. but that doesn't make sense to me. Seems like you have a different workflow.
Users browsing this forum: Baidu [Spider] and 63 guests
