ipisoft.com
https://forum.ipisoft.com/
Two questions about Kinect capture
https://forum.ipisoft.com/viewtopic.php?f=4&t=5457
Page 1 of 2
Author:  apside [ Thu Oct 20, 2011 6:33 am ]
Post subject:  Two questions about Kinect capture
Is it possible to capture in 25 FPS in the future ? I'm a french user and the standard FPS here is 25 FPS.
And is it normal that feet are not "touching" the ground when I put the right height of the model ?
I have to exagerate much more the height of the model. (1.85m to 2.03 m)
Author:  andrew [ Thu Oct 20, 2011 11:27 am ]
Post subject:  Re: Two questions about Kinect capture
Kinect Sensor does not support 25 FPS.
What happened after "Refit Pose" button clicking? Is 1.85m-model aligned correctly? If no then please provide us with screenshots.
Author:  apside [ Fri Oct 21, 2011 1:10 am ]
After clicking refit pose, this is the result
Author:  Greenlaw [ Fri Oct 21, 2011 9:27 am ]
Is the calibration correct? A quick way to check is to rotate your view and look at where the cameras are position. If they are positioned where you expect them, then it's probably okay. But if they are sharing the same space, then the calibration data is missing. Try reloading the data. If that doesn't work, you many need to recalibrate the scene data and resave it, or just start over from scratch.
Also, check the height of your actor. It appears to be shorter than the performer's volume.
This doesn't explain why the feet are floating though; my guess is that we're looking at a combination of the two problems.
Hope this helps.
(FWIW, my very first two-Kinect calibration effort failed miserably, probably because I missed a step. After that, I've had perfect calibration every time, so it's very important to follow all the steps.)
Author:  apside [ Mon Oct 24, 2011 12:14 am ]
Hello.
Thanks for the reply. This is a one kinect capture so there is no calibration to do I think.
It's very strange because before the last realese, there was no problème.
Author:  andrew [ Mon Oct 24, 2011 4:37 am ]
Could you please share with us your video and project files? Video can be short (only background and T-pose).
Also note that you can rollback to the previous version of iPi Studio:
- Open Control Panel.
- Choose Add/Remove Programs
- Select "iPi Desktop Motion Capture" item in list of installed software
- Click Remove/Change button above the list
- In the dialog "iPi Desktop Motion Capture Maintenance" select "Restore the application to its previous state" and click Ok
- Skip autoupdate during starting of iPi Studio
Author:  apside [ Mon Oct 24, 2011 7:15 am ]
I can't return to previous version when I try to click Remove/Change button.
When I saw this problem, I try to reinstall.
the video and the project here
Author:  andrew [ Mon Oct 24, 2011 7:36 am ]
Then you can deinstall iPi Studio and install the previous version from here:
http://www.ipisoft.com/downloads/iPiStudioSetup-1.2.0.120.exe
Author:  apside [ Mon Oct 24, 2011 7:39 am ]
Thanks very much
here the project and the video
http://dl.free.fr/iEwM1MbFY
Author:  apside [ Mon Oct 24, 2011 7:47 am ]
OK with the old version everything works well, the height of the actor fit well and feet are on the ground.
But when i open a mocap file made with the last realese of pisoft, the program crash
Page 1 of 2 All times are UTC - 8 hours [ DST ]
http://www.phpbb.com/
