| Preferences wen starting iPi. https://forum.ipisoft.com/viewtopic.php?f=4&t=5490 |
Page 1 of 1 |
| Author: | mrbones [ Sun Nov 06, 2011 3:36 pm ] |
| Post subject: | Preferences wen starting iPi. |
I would need the iPi to come up with a pre set of preferences. Meaning, When I start iPi. The Grid is off, background set to dark blue, skeleton strobe off, and showdepth enabled. THis is because it takes about 15 seconds to do this everytiime I open iPi. I want it to be exactly how I want it when it starts. I think it would be called Preferences...under edit menu. or Control P. Thanks |
| Author: | mitchfx [ Sun Jan 22, 2012 6:46 pm ] |
| Post subject: | Re: Preferences wen starting iPi. |
I wholeheartedly agree! Even if it was a text based ini file we had to manually create that would be better than having to change your settings every time you start the program. Sometimes I forget to check shoulder tracking and don't realize it until the process has been going for several minutes...time wasted. Thanks, Mitch |
