| The T pose https://forum.ipisoft.com/viewtopic.php?f=4&t=6186 |
| Author: | aodusany [ Sat Jul 21, 2012 1:41 am ] |
| Post subject: | The T pose |
I use Poser Pro 2012. The problem I encounter is that the BVH goes into the wrong place when loaded to the avatar in PP2012. I have tried to use the t pose on first frame from recorder setting, however this is not good enough, because frame 2 and onwards move from the T pose into the original position when recorded (could move a long way from the T pose on the X and Z). This causes nightmare in cloth room and Marvelous Designer. You may already have the solution, but I do not know of it yet. Suggestions: In the recorder: A) When you make the T pose could you have a silhouette which shows you the correct position in space to be on the screen. B) Could the T pose automatically calibrate to the correct T pose position in space, either on the recorder or in studio? Hoping for a positive solution. |
| Author: | vmaslov [ Mon Jul 23, 2012 1:42 am ] |
| Post subject: | Re: The T pose |
Please check if recentering coordinate system on character resolves your problem. See this topic: http://forum.ipisoft.com/viewtopic.php?f=5&t=6166. |
| Author: | aodusany [ Mon Jul 23, 2012 3:22 am ] |
Thanks works great. |
