It is currently Sun Nov 08, 2026 8:24 pm
PostPosted: Wed Aug 15, 2012 5:55 am
Hello,
After practically pulling apart my entire apartment to make room to shoot correctly with 4 cameras, I calibrated the scene without hassle and then began my recording.
Soon after, my SSD hit max capacity and crashed the program.
After restarting (without modifying my camera setup) I went straight into recording - only I hadnt re-ordered my cameras prior to the shoot!
Now I have 100 gigs of tracked movements, that dont comply with my setup (which was since taken apart) because camera 3 and 4 are switched.
please help
Benjamin Swinbanks
PostPosted: Wed Aug 15, 2012 8:00 am
If I correctly understand your problem - you have calibration video with one camera order, and action videos with another camera order. Unfortunately, currently we have no automatic solution for such situations. However, you can do something manually.
When you're finished with calibration process, you get the scene file. Essentially, this is an XML file with the list of camera positions. So you can open it in text editor and reorder Camera elements so they correspond to your action videos. In case you are not familiar with XML - single Camera element is all text starting from <Camera and ending with the next </Camera>.
PostPosted: Wed Aug 15, 2012 10:12 am
Fantastic, that was my exact problem
Thanks a lot I will try this now and get back to you
Thanks Again
PostPosted: Wed Aug 15, 2012 4:04 pm
(Update)
Clear and simple - thanks for the advice! Great program :)
Ben
Users browsing this forum: No registered users and 177 guests
