It is currently Sun Nov 08, 2026 10:44 pm
PostPosted: Tue Dec 30, 2014 2:03 pm
every time I try to use the IPI Recorder it crashes immediately on startup and gives this error message (Win7)
iPi Recorder 2.2.3.30
OS: Microsoft Windows NT 6.1.7601 Service Pack 1 (64 bits)
.NET: 4.0.30319.18408
CPU count: 4
GC: workstation (Interactive)
Running in 64 bits
System.OutOfMemoryException: Retrieving the COM class factory for component with CLSID {56FDF344-FD6D-11D0-958A-006097C9A090} failed due to the following error: 8007000e Not enough storage is available to complete this operation. (Exception from HRESULT: 0x8007000E (E_OUTOFMEMORY)).
at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
at System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
at System.Activator.CreateInstance(Type type, Boolean nonPublic)
at System.Activator.CreateInstance(Type type)
at System.Windows.Window.ApplyTaskbarItemInfo()
at System.Windows.Window.WindowFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.PublicHooksFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
whats odd is that it worked fine before. Anyone got a solution? Maybe I installed some type of conflicting software?
PostPosted: Fri Jan 02, 2015 4:12 am
I quote here the answer you've already got to your email.
Have you already tried a suggested solution and what's the result?
andrew wrote:
Hello Frank,
Most likely this means that you have some troubles with your environment. Fast googling gives the following results:
- https://forums.adobe.com/thread/1167217?tstart=0
- http://beta.cursevoice.com/forums/beta- ... mory-error
In both cases the root of problem was in 3d party software/drivers.
Please, try the following:
1. Update all drivers on your system, including graphics
2. Reinstall MS .Net Framework 4.5.1 or 4.5.2
3. Reboot
Hope, something of this will help.
PostPosted: Fri Jan 02, 2015 4:25 am
Yes, thank you very much for your email over the holiday. I didn't understand I suppose how the forum worked and thought nobody would see my post. I updated the .NET stuff with no avail .It makes sense that the issue would be with my graphics card driver as I've been having issues with that lately with other softwares but I haven't been able to find the correct driver for it as it is a switchable graphics laptop. I ordered another computer by so I'm hoping that one will work when I get it. The Ipi program seems to run fine however. Thank you again for your work towards making great software and also being so attentive.
PostPosted: Fri Jan 02, 2015 4:55 am
This is a SPAM protection measure. A first post of a new user should be approved by moderators before regular users can see it.
Users browsing this forum: No registered users and 131 guests
