It is currently Sun Nov 08, 2026 4:10 pm
PostPosted: Wed Feb 19, 2020 3:12 pm
Hello I am trying just replay a recorded view on Recorder it seems to be throwing an error, maybe when there is a frame gap.
Recorded on Ipi recorder 4.4.4.81
Kinect for Azure.
It will play fine up to this frame, and if I skip over the frame and start after it works fine... until next frame gap.
Any help is appreciated.
Code:
iPi Recorder 4.4.4.81
OS: Microsoft Windows NT 10.0.18362.0 (64 bits)
.NET: 4.7.2.528040
CPU count: 8
GC: workstation (Interactive)
Running in 64 bits
System.AggregateException: One or more errors occurred. ---> System.NotSupportedException: No imaging component suitable to complete this operation was found. ---> System.Runtime.InteropServices.COMException: The component cannot be found. (Exception from HRESULT: 0x88982F50)
   at System.Windows.Media.Imaging.BitmapDecoder.SetupDecoderFromUriOrStream(Uri uri, Stream stream, BitmapCacheOption cacheOption, Guid& clsId, Boolean& isOriginalWritable, Stream& uriStream, UnmanagedMemoryStream& unmanagedMemoryStream, SafeFileHandle& safeFilehandle)
   at System.Windows.Media.Imaging.BitmapDecoder..ctor(Stream bitmapStream, BitmapCreateOptions createOptions, BitmapCacheOption cacheOption, Guid expectedClsId)
   at System.Windows.Media.Imaging.JpegBitmapDecoder..ctor(Stream bitmapStream, BitmapCreateOptions createOptions, BitmapCacheOption cacheOption)
   at #=zOF8faGOR5fOX2r_1DuvO$mevsJnvuHw3Zu31sl8=.#=zmPwhZXeKO3BRQCquKg==(Byte[] #=zLd1rFDI=, Int32 #=z8$QiVTU=, Int32 #=z6tC6uYY=, Byte[] #=zQX2WQlJcigFR, BitmapInfo& #=zxVPTWjU=)
   at #=zbkPomS2pQjbPGc_MC0rb30n0tShigTli2w3pYZhhdWZYALtzTw==.#=zgnfp53E=(Byte[] #=zLd1rFDI=, Int32 #=z8$QiVTU=, Int32 #=z6tC6uYY=, Byte[] #=zQX2WQlJcigFR)
   at #=z1AN6ahD6c7CnF3iddyU23Bw=.#=zCSdAgO3hS4GdjB2s44M9U1s=.#=znnScZmx6O5otWxeKNQ==(Byte[] #=zHAaBasuOGGvL)
   at #=zqHlsIeVNbYwpQFcZv5$Xqfc6c05E.#=z5ys9DzWbiqPK(Action`1 #=zOnXLDB6Gif7i)
   at #=z1AN6ahD6c7CnF3iddyU23Bw=.#=zhL2fdpPk7MKM(#=zKPCl8M_LM5nC62OHMA== #=zj6YrC78=)
   at #=zZ1ZaC4T3aTAVNk$AxA==.#=zvU4uygibZkhmWLFJr7QGEPw=.#=z$9r_6iUsU2H9WVcn9Q==(#=zZNv5x5the5m2y5Z0_vE69uI= #=z0MPiCiw=)
   at System.Threading.Tasks.Parallel.<>c__DisplayClass17_0`1.<ForWorker>b__1()
   at System.Threading.Tasks.Task.InnerInvokeWithArg(Task childTask)
   at System.Threading.Tasks.Task.<>c__DisplayClass176_0.<ExecuteSelfReplicating>b__0(Object <p0>)
   at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
   at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
   at System.Threading.Tasks.Parallel.ForWorker[TLocal](Int32 fromInclusive, Int32 toExclusive, ParallelOptions parallelOptions, Action`1 body, Action`2 bodyWithState, Func`4 bodyWithLocal, Func`1 localInit, Action`1 localFinally)
   at System.Threading.Tasks.Parallel.ForEachWorker[TSource,TLocal](IEnumerable`1 source, ParallelOptions parallelOptions, Action`1 body, Action`2 bodyWithState, Action`3 bodyWithStateAndIndex, Func`4 bodyWithStateAndLocal, Func`5 bodyWithEverything, Func`1 localInit, Action`1 localFinally)
   at System.Threading.Tasks.Parallel.ForEach[TSource](IEnumerable`1 source, Action`1 body)
   at #=zZ1ZaC4T3aTAVNk$AxA==.#=zhL2fdpPk7MKM(#=zKPCl8M_LM5nC62OHMA== #=zj6YrC78=)
   at #=zZ1ZaC4T3aTAVNk$AxA==.#=zKv8UeVej7nU5j_bYeE8nzP0=(#=zKPCl8M_LM5nC62OHMA== #=zj6YrC78=)
   at #=zZ1ZaC4T3aTAVNk$AxA==.#=znIZM1UByvuvB.#=z6bHYsAo=(Int32 #=z3TPwzs4=, Action`1 #=zmwsGAOY=)
   at #=zZ1ZaC4T3aTAVNk$AxA==.#=zhL2fdpPk7MKM(Int32 #=zJsVsdHE=)
   at #=zZ1ZaC4T3aTAVNk$AxA==.#=zsnXLD5__sxaQ(Int32 #=zFT06bto=)
   at iPiRecorder.ViewModel.PlaybackController.SetTimeTrackValue(Double value)
   at iPiRecorder.ViewModel.PlaybackController.set_TimeTrackValue(Double value)
   at -.dje_zBGGQPL8ESYSJ783WZU5WBDGJDSNQ_ejd.#=zPfwdb10OBzwF()
---> (Inner Exception #0) System.NotSupportedException: No imaging component suitable to complete this operation was found. ---> System.Runtime.InteropServices.COMException: The component cannot be found. (Exception from HRESULT: 0x88982F50)
   at System.Threading.Tasks.Task.<>c__DisplayClass176_0.<ExecuteSelfReplicating>b__0(Object <p0>)<---
PostPosted: Thu Feb 20, 2020 2:19 am
Can you share an .ipivideo file so we take a look? You may send a link to our support email if you don't want to post it here.
PostPosted: Thu Feb 20, 2020 4:15 am
Does also Mocap Studio crash when tracking this video?
The problem may be related to Windows Camera Frame Server service which sometimes causes cameras to produce corrupted frames. Before recording next time try closing all aps that can use camera - e.g. video messengers, video recording apps etc. This may help in preventing frame gaps and bad frames issues.
PostPosted: Thu Feb 20, 2020 7:19 am
Studio crashes as well. I will send video to support email. Thank you.
Users browsing this forum: No registered users and 148 guests
