It is currently Sun Nov 08, 2026 3:27 pm
PostPosted: Sun Jun 06, 2010 4:15 am
After importing my calibrated scene setup and then carefully setting up a T pose on a new bit of capture footage, sometimes the software thinks the model is about a foot lower than it actually is, and compensates by raising it up. Predictably, it then gets very confused!
You can see screenshots I took in this zipfile:
http://www.ian.chisholm.clara.net/pose_mismatch_bug.zip
You can see I lined the T-Pose up properly, and then I used the "Pose Mismatch" display to see why it kept going wrong. Oddly, the Pose Mismatch view thinks the model is about a foot lower than it actually is. Raising the arm of the model shows a green match further up (as shown by Bad Pose Matching.jpg).
I've experienced this a few times now, but it doesn't happen every time. It is always the same height differential as well.
However, if you make the T-pose, save the .mocap file, quit the software and then reopen it all, the mismatching goes away, so there is a workaround.
PostPosted: Mon Jun 14, 2010 2:30 pm
After more usage, I found that this bug only happens if you load a new video file in after working on one earlier. Basically you have to close and reopen IPISoft for each recording you work on, or it moves the actor about a foot too high.
PostPosted: Thu Jun 17, 2010 12:17 pm
Thank you very much for your feedback. This was a bug and it is fixed in latest release.
Users browsing this forum: Google [Bot] and 135 guests
