It is currently Sun Nov 08, 2026 3:26 pm
PostPosted: Thu Aug 12, 2010 5:03 am
I just installed evaluation version yesterday and today I wanted to share my first test I saved yesterday but I can't open files and I can't load scene. Pressing open just make the border of the application flashing one time (blinking white).
PostPosted: Thu Aug 12, 2010 4:47 pm
I was able to open it suddenly I don't know why and I could render my video. It's in the video section. viewtopic.php?f=12&t=3989
but right after that i could not open anything again... So I can't test it anymore...
I use windows 7 on a dual xeon quad core nehalem with 12 gig of Ram.
PostPosted: Wed Aug 18, 2010 1:50 am
could you describe your problem in more details:
1) does File Open Dialog appear?
2) can you open existing *.MoCap project file by double clicking it in Windows Explorer?
3) can you open AVI files in iPiStudio?
P.S. This problem doesn't concern to trial period limitations.
PostPosted: Wed Aug 18, 2010 4:19 pm
Hi, thank for your reply!
1) no, the application border just flashes white for a second when I press "open".
2)Yes, if I click on a .mocap file, it opens in ipistudio but the open button still doesn't work.
3)no. open button is not working...
I just notice something: if I open a second instance of the software, that one wil work normally and the open button is working fine.
PostPosted: Wed Aug 18, 2010 5:13 pm
Mysticism!
Very simple code is working to show open file dialog. The only similar problem is discussed here but without success in clarification.
Great that you find a workaround!
PostPosted: Wed Aug 18, 2010 5:37 pm
Yes I guess I will just have to open 2 instances of the software for the moment. I will try installing it on another machine with the same specs to see how it goes.
PostPosted: Fri Dec 03, 2010 5:57 pm
I am having the exact same problem on my end. The dual instance works! Nice find!
PostPosted: Tue Jan 11, 2011 3:46 pm
I have the same problem too. When I click open, load scene, save scene or any other button, the application window is flashing once. No dialog appears.
Windows 7 (64)
AMD Phenom II X4 3,40 GHz
8 GB RAM
PostPosted: Wed Jan 12, 2011 12:00 pm
The dual instance trick doesn't work for me.
I would really like to try this software.
Any Ideas how to get it to work?
Users browsing this forum: Google [Bot] and 180 guests
