It is currently Sun Nov 08, 2026 8:20 pm
PostPosted: Fri Mar 04, 2011 10:55 am
For some reason Ipisoft keeps opening my video recordings upside down, does any one know how to fix this?
Any help is appreciated, Thanks!
PostPosted: Mon Mar 07, 2011 3:57 pm
Possible reason for this is some broken video codec installed on your computer. Please use GSpot ( http://www.headbands.com/gspot/ ) to find out what codec your computer uses when playing the file. If GSpot shows any codec other then Microsoft MJPEG is used for playing your video file (recorded with iPiRecorder) then you may need to remove the problematic codec to fix the problem.
PostPosted: Mon Mar 07, 2011 8:02 pm
Thanks for the response! I used the software and it shows Bl_RGB as the codec and the video name as Bl_RGB Raw Bitmap, and the status as no codec required. It does show the video upside down. Any suggestions as how to fix? Thanks!
PS I am running Win 7 Pro 64bit.
PostPosted: Mon Mar 07, 2011 11:00 pm
PROBLEM SOLVED! Installed CCCP software and it seems to work now! Thanks!
Users browsing this forum: No registered users and 63 guests
