It is currently Tue Oct 27, 2026 8:06 am
Post a new topicPost a reply Page 2 of 2   [ 16 posts ]
PostPosted: Thu May 30, 2013 1:33 am
Burgija wrote:
I connect the PS move via cable and click the PS button and it looks like its connecting but the process never ends.
Do you press the PS button repeatedly, every time when LED indicator turns off during pairing?
Burgija wrote:
I also tried with motion in joy and it seem to be paired (the red light is not flashing) but ipi doesn't see it.
That's strange. Do you use the version 0.7.1001 of Motion in Joy drivers? iPi Recorder may not work with other versions.
PostPosted: Fri Jun 14, 2013 7:38 pm
Had the same problem with the same ASUS BT-211 blue tooth dongle. Had to make sure you remove the motion in joy driver if installed Windows 7 64 bit went to ASUS site downloaded the latest 32 bit and 64 bit driver . installed the 32 bit driver Windows 64 bit OS IPI RECORDER latest version paired the two PS move controllers with no problem have not tried MOCAP session yet will try tonight or tomorrow .I closed and restarted IPI REcorder kept the two PS Move Motion Sensors paired with no issues
PostPosted: Tue Jul 30, 2013 10:29 am
i actually bought a psmoove + a usb bluetooth adapter (because ithought it was because of my built in bluetooth adaptater .
I test many solutions and nothing going on the good way . My pc detect psmove but i can't do nothing
(i have win 8 )
PostPosted: Thu Aug 01, 2013 2:38 am
Have you successfully paired PS Move with BT adapter using MotioninJoy DS3 tool?
PostPosted: Wed Aug 07, 2013 5:49 am
nope , i jsut bought a second kinect and damn i'm so mad at bluetooh . psmoove + bluetooth adaptater for nothing.
i tried motion joy etc never succeed.
PostPosted: Wed Aug 07, 2013 6:12 am
On Win8, Recorder (usually) supports PS Move via MotioninJoy BT-drivers only.
http://wiki.ipisoft.com/Motion_in_Joy_Installation
What had you stuck with in DS3 tool? Does it succeed installing driver for your BT-adapter?
