It is currently Tue Oct 27, 2026 2:18 am
Post a new topicPost a reply Page 3 of 4   [ 37 posts ]
 Post subject: Re: demo install fails
PostPosted: Fri Jan 11, 2013 4:53 am
You need to change current folder in command line to <Windows folder>\Microsoft.NET\Framework\v3.5 before running gacutil. For example, if Windows is installed in C:\Windows then you should first execute in command line:
Code:
c:
cd \Windows\Microsoft.NET\Framework\v3.5
PostPosted: Fri Jan 11, 2013 9:54 am
Yes I know I did that I have basic knowlage of how the command line works. And it does not recognise it. Also there is a framework64 folder. Maybe I can try that folder?
PostPosted: Sat Jan 12, 2013 5:01 am
Sorry, may bad :/ Gacutil is also a part of Windows SDK, as Fusion Log Viewer. I've attached zipped EXE.
Have you tried with XNA Game Studio yet?
File comment: Global Assembly Cache utility
gacutil.zip [48.76 KiB]
Downloaded 728 times
PostPosted: Mon Jan 14, 2013 11:23 am
XNA Game Studio requires me to install Visual Studio 2008 Express and I'm having a hard time installing that. This is what gacutil says:
Microsoft (R) .NET Global Assembly Cache Utility. Version 3.5.30729.1
Copyright (c) Microsoft Corporation. All rights reserved.
The Global Assembly Cache contains the following assemblies:
Number of items = 0
PostPosted: Mon Jan 14, 2013 12:26 pm
Seems XNA Framework does not install properly - the assembly "Microsoft.Xna.Framework" should be placed in GAC during installation. Did you run its installer with administrative privileges?
You can also try to install this assembly in GAC manually:
  • Extract Microsoft.Xna.Framework.dll from xnafx30_redist.msi. You can use 7-zip for that.
  • Place it in the same directory where gacutil resides.
  • Open command line with administrative privileges (run as administrator), and execute:
    Code:
    gacutil /i Microsoft.Xna.Framework.dll
PostPosted: Tue Jan 15, 2013 11:28 am
No I didn't run the install with admin privilegies. There seems to be no Microsoft.Xna.Framework.dll in the install. There are Microsoft_Xna_Framework_dll_GAC and Microsoft_Xna_Framework_Game_dll_GAC inside the archive which are recognized as a "File" type i.e unrecognizable.
Should I rename them? Maybe it is a corrupt install?
PostPosted: Wed Jan 16, 2013 2:10 am
First try to run XNA Framework installation with admin privileges.
If it does not help, follow instructions for manual installation. Extract Microsoft_Xna_Framework_dll_GAC and rename it to Microsoft.Xna.Framework.dll.
PostPosted: Wed Jan 16, 2013 11:52 am
Hmm... Both solutions lead to the same result even though I am running them as admin. This is what it said in the console when I tried manual install:
Failure adding assembly to the cache: Access denied. You might not have administ
rative credentials to perform this task. Contact your system administrator for a
ssistance.
PostPosted: Wed Jan 16, 2013 1:21 pm
Try logging with 'Administrator' user (which is setup at OS installation), and also running command line with admin privileges (right click, 'Run as administrator').
PostPosted: Thu Jan 17, 2013 10:21 am
How do I do that? I see only my profile and it has administrator rights.
Users browsing this forum: No registered users and 14 guests
