It is currently Sun Nov 08, 2026 7:07 pm
PostPosted: Tue Dec 15, 2009 7:49 pm
Why would camera 1 not move? My calibration was pretty much on but now i am noticing my back foot hovering in the air a tad.
Also saving scean does not save scale... and saving and loading actor does not set the right settings.
PostPosted: Fri Dec 18, 2009 9:43 am
Camera 1 is not supposed to move during calibration. Calibration finds position of other cameras relative to camera 1, up to scale.
You need to define ground points in order to properly orient cameras (including camera 1) ralative to ground plane.
After you defined ground points, you can set correct scale (using "Scale" control on "Calibration" tab), based on camera heights over ground as a reference.
We will double-check that. If it does not save scale, we will fix it in upcoming version.
We will look into this. Could you please provide more specific information - what particular actor settings are not being saved/loaded?
Users browsing this forum: No registered users and 113 guests
