| Very low FPS on Kinect V2 version iPi Recorder V4 https://forum.ipisoft.com/viewtopic.php?f=5&t=10134 |
| Author: | wapeddell [ Fri Jun 14, 2019 5:08 pm ] |
| Post subject: | Very low FPS on Kinect V2 version iPi Recorder V4 |
My spec are Ryzen 2700x @4.0GHZ, 16GB of RAM, 1080TI 11GB, and SSDs for storage. I'm getting between 5-10 FPS when I go into iPi Recorder. Please advise how to fix this issue. |
| Author: | vmaslov [ Sun Jun 16, 2019 8:11 am ] |
| Post subject: | Re: Very low FPS on Kinect V2 version iPi Recorder V4 |
Most probably it's an USB issue. As you're on AMD CPU I guess your USB 3.0 ports are served by AMD USB controller. While Kinect 2 is known to work best with Intel and NEC controllers. Anyway, try all available USB 3.0 ports. If no luck then you'll need to install a PCIe card with NEC USB 3.0 chip and connect to it. |
| Author: | wapeddell [ Sun Jun 16, 2019 2:42 pm ] |
vmaslov wrote: Most probably it's an USB issue. As you're on AMD CPU I guess your USB 3.0 ports are served by AMD USB controller. While Kinect 2 is known to work best with Intel and NEC controllers. Anyway, try all available USB 3.0 ports. If no luck then you'll need to install a PCIe card with NEC USB 3.0 chip and connect to it. Yeah I disconnected all my USB devices and tried all ports. After doing so it finally worked in one port, therefore, I can say the issue is resolved. |
