It is currently Sun Nov 08, 2026 4:52 pm
PostPosted: Wed Jul 01, 2020 10:29 am
PS move Controllers are calibrated, the rotation is fine, Matched with camera #1 ,
it's just that the rotation is inverted on one axis.
Like if i had to hold them reversed instead of straight foward.
When i use a psmove on my head, rotations are fine.
Is there a work around to fix that ?
*video attached*
PostPosted: Fri Jul 03, 2020 3:56 am
Did you use the same controller for the head or a different one?
I see you've got controllers attached to both of your hands. And the one in the right hand rotates like if it is in the left hand. Probably you confused assignment of controllers between hands? Try swapping them.
If that doesn't solve your problem, please share your video and project. Send links to our tech support email if you don't want to share in public.
PostPosted: Sun Jul 05, 2020 6:44 am
I'm a bit ashamed, I did confused assignment of controllers between hands.
Thanks for the help vmaslov !
Users browsing this forum: No registered users and 126 guests
