PostPosted: Sun Jan 17, 2010 3:34 pm
I downloaded the Calibration .zip file then tried to run the setup. I get the following error:
Application download did not succeed. Check your network connection or contact your system administrator or network service provider.
The details are below:
PLATFORM VERSION INFO
Windows : 6.0.6000.0 (Win32NT)
Common Language Runtime : 4.0.20506.1
System.Deployment.dll : 4.0.20506.1 (Beta1.020506-0100)
clr.dll : 4.0.20506.1 (Beta1.020506-0100)
dfdll.dll : 4.0.20506.1 (Beta1.020506-0100)
dfshim.dll : 4.0.20428.1 (Beta1.020428-0100)
SOURCES
Deployment url : file:///C:/Users/stevem/Desktop/iPiCalibrationTool/iPiCalibrationTool.application
Deployment Provider url : http://www.ipisoft.com/downloads/iPiCal ... pplication
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of C:\Users\stevem\Desktop\iPiCalibrationTool\iPiCalibrationTool.application resulted in exception. Following failure messages were detected:
+ Downloading http://www.ipisoft.com/downloads/iPiCal ... pplication did not succeed.
+ Unable to connect to the remote server
+ An attempt was made to access a socket in a way forbidden by its access permissions 72.167.232.223:80ac
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
There were no warnings during this operation.
OPERATION PROGRESS STATUS
* [1/17/2010 5:23:37 PM] : Activation of C:\Users\stevem\Desktop\iPiCalibrationTool\iPiCalibrationTool.application has started.
ERROR DETAILS
Following errors were detected during this operation.
* [1/17/2010 5:23:38 PM] System.Deployment.Application.DeploymentDownloadException (Unknown subtype)
- Downloading http://www.ipisoft.com/downloads/iPiCal ... pplication did not succeed.
- Source: System.Deployment
- Stack trace:
at System.Deployment.Application.SystemNetDownloader.DownloadSingleFile(DownloadQueueItem next)
at System.Deployment.Application.SystemNetDownloader.DownloadAllFiles()
at System.Deployment.Application.FileDownloader.Download(SubscriptionState subState)
at System.Deployment.Application.DownloadManager.DownloadManifestAsRawFile(Uri& sourceUri, String targetPath, IDownloadNotification notification, DownloadOptions options, ServerInformation& serverInformation)
at System.Deployment.Application.DownloadManager.DownloadManifest(Uri& sourceUri, String targetPath, IDownloadNotification notification, DownloadOptions options, ManifestType manifestType, ServerInformation& serverInformation)
at System.Deployment.Application.DownloadManager.DownloadDeploymentManifestDirect(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, IDownloadNotification notification, DownloadOptions options, ServerInformation& serverInformation)
at System.Deployment.Application.DownloadManager.FollowDeploymentProviderUri(SubscriptionStore subStore, AssemblyManifest& deployment, Uri& sourceUri, TempFile& tempFile, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.DownloadManager.DownloadDeploymentManifestBypass(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, SubscriptionState& subState, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
--- Inner Exception ---
System.Net.WebException
- Unable to connect to the remote server
- Source: System
- Stack trace:
at System.Net.HttpWebRequest.GetResponse()
System.Net.Sockets.SocketException
- An attempt was made to access a socket in a way forbidden by its access permissions 72.167.232.223:80
- Source: System
- Stack trace:
at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.Sockets.Socket.InternalConnect(EndPoint remoteEP)
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Int32 timeout, Exception& exception)
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
Anyone know what the problem is?
PostPosted: Sun Jan 17, 2010 5:46 pm
More information:
I tried to install the software on my PC at home and it installed fine. After looked at the details again above, I'm thinking it's a .NET error. I'll have my friend double-check his .NET version.
PostPosted: Sun Jan 17, 2010 6:13 pm
Of course now as I read more into what I'm doing I realize that the calibration tool is basically not needed anymore. I feel like an idiot.
PostPosted: Mon Jan 18, 2010 9:23 am
Early on I too spent a lot of time with it before realizing I didn't need it. :)
Anyway, I believe the Calibration tool is still used if you're not using a Logitech camera, which seems to have a consistent fov of around 75, which is DMC's default setting now.
I don't have Calibration installed anymore but, FYI, it did run on my system. I just tried downloading it now, and that went fine too...their server must have had a 'hiccup' when you tried to download earlier.
PostPosted: Sat Feb 13, 2010 7:23 pm
Hello, I am an absolute newbie to this software and I really like its idea a lot but I'm stack right on the first tutorial - http://www.youtube.com/watch?v=bko8gPKh ... 8&index=39
Even when I import the video I'm going to use I still don't have a "calibration" tab, so I just wanted to ask is this that calibration tool you're talking about? Is that the thing that I don't need anymore? or is this perhaps some other calibration that is indeed necessary?
Any help would be appreciated! :)
Users browsing this forum: No registered users and 158 guests
