ipisoft.com
https://forum.ipisoft.com/
Cannot Open Video
https://forum.ipisoft.com/viewtopic.php?f=5&t=1776
Page 1 of 1
Author:  SuperMouseDV [ Thu Feb 11, 2010 9:17 pm ]
Post subject:  Cannot Open Video
I captured a Series of videos (about 15) to do an indepth test of
IPISofts motion capture software. My Main computer crashed so I decided
to upgrade to Windows 7 64. I get this error now.
Cannot open video: incorrect video frame indexing. Please fix indexing or convert the video to unbcompressed avi.
What happened.. They play fine through Windows Media.
Any Suggestions.
Thanks
Hal
Author:  obin [ Sat May 15, 2010 3:28 pm ]
Post subject:  Re: Cannot Open Video
yea...run it through QUICKTIME PRO to make a NEW AVI file with NO codec..some type of bug I can't open recorded files but doing this will work
Author:  Michael Nikonov [ Mon May 17, 2010 9:35 am ]
A workaround is to convert the file to uncompressed AVI.
VirtualDub ( http://www.virtualdub.org ) can be used for conversion. VirtualDub is free.
Author:  minc [ Thu Sep 22, 2011 10:29 pm ]
Hi. I have converted my video to uncompressed AVI using virtualdub. But I get the exact same error message...
Author:  camvfxUSA [ Wed Oct 05, 2011 12:24 pm ]
I was able to duplicate the same error message when I tried to use a multi-core GPU card. I tried opening the same captured file using an i5 PC with an Nvidia GX570 and it worked perfectly. I have not completed all varible testing to confirm this possibility but it is my opinion that professional grade gpu cards may actually be a detriment, as well as expensive.
Author:  dyrwoolf [ Fri Nov 04, 2011 11:43 am ]
Same problem.
I run it throu VirtuaDub but it still is unable to open. I have dual grapichs card and quad processor.
Im gonna try do this on my laptop tomorrow.
Get back to this thread after.
Author:  Michael Nikonov [ Fri Nov 04, 2011 12:13 pm ]
This can be a problem with video codecs on your computer:
http://www.ipisoft.com/en/wiki/index.ph ... c_problems
Author:  borsaci21 [ Thu May 03, 2012 8:18 am ]
I have the same problem.
No matter which video I try to open in ipi-soft, I get a error Message, so that I cannot open any video.
I used virtualdub to decompress the video file, but it did not help.
Then I wrote in the command probt " regsvr32 quartz.dl " , but I still cannot open any video.
I use:
- ipsoft Version 1.2.0.117
- Intel(R) Core(TM) i3-2100 CPU 3.10 GHz
- Windows 7 64-bit
- nVidia Quadro 4000
Can you please help me ?
Author:  camvfxUSA [ Sun May 06, 2012 3:49 pm ]
Hi. You never need to compress nor decompress your captured video. Please let me know what type and how many cameras you used with iPiRecorder to capture the motion; the path to the location you saved the file; and the version of both Recorder and Studio you are using. I am sure I can get you going with this data. Jake
Author:  borsaci21 [ Mon May 07, 2012 4:40 am ]
Sorry it was my mistake .Everthing fine.
Many thanks.
borsaci21
http://www.phpbb.com/
