| can't open files, can't load scenes https://forum.ipisoft.com/viewtopic.php?f=5&t=3985 |
| Author: | Strob [ Thu Aug 12, 2010 5:03 am ] |
| Post subject: | can't open files, can't load scenes |
I just installed evaluation version yesterday and today I wanted to share my first test I saved yesterday but I can't open files and I can't load scene. Pressing open just make the border of the application flashing one time (blinking white). |
| Author: | Strob [ Thu Aug 12, 2010 4:47 pm ] |
| Post subject: | Re: can't open files, can't load scenes |
I was able to open it suddenly I don't know why and I could render my video. It's in the video section. viewtopic.php?f=12&t=3989 but right after that i could not open anything again... So I can't test it anymore... I use windows 7 on a dual xeon quad core nehalem with 12 gig of Ram. |
| Author: | andrew [ Wed Aug 18, 2010 1:50 am ] |
Hello, could you describe your problem in more details: 1) does File Open Dialog appear? 2) can you open existing *.MoCap project file by double clicking it in Windows Explorer? 3) can you open AVI files in iPiStudio? P.S. This problem doesn't concern to trial period limitations. |
| Author: | Strob [ Wed Aug 18, 2010 4:19 pm ] |
Hi, thank for your reply! 1) no, the application border just flashes white for a second when I press "open". 2)Yes, if I click on a .mocap file, it opens in ipistudio but the open button still doesn't work. 3)no. open button is not working... I just notice something: if I open a second instance of the software, that one wil work normally and the open button is working fine. |
| Author: | andrew [ Wed Aug 18, 2010 5:13 pm ] |
Mysticism! Very simple code is working to show open file dialog. The only similar problem is discussed here but without success in clarification. Great that you find a workaround! |
| Author: | Strob [ Wed Aug 18, 2010 5:37 pm ] |
Yes I guess I will just have to open 2 instances of the software for the moment. I will try installing it on another machine with the same specs to see how it goes. |
| Author: | ghenson [ Fri Dec 03, 2010 5:57 pm ] |
I am having the exact same problem on my end. The dual instance works! Nice find! |
| Author: | FabianSchempp [ Tue Jan 11, 2011 3:46 pm ] |
I have the same problem too. When I click open, load scene, save scene or any other button, the application window is flashing once. No dialog appears. Windows 7 (64) AMD Phenom II X4 3,40 GHz 8 GB RAM |
| Author: | FabianSchempp [ Wed Jan 12, 2011 12:00 pm ] |
The dual instance trick doesn't work for me. I would really like to try this software. Any Ideas how to get it to work? |
