| I can't use PSEye with USB3.0 https://forum.ipisoft.com/viewtopic.php?f=5&t=4885 |
| Author: | nagahata [ Tue Feb 15, 2011 6:04 am ] |
| Post subject: | I can't use PSEye with USB3.0 |
Hi there :) I can't use PSEye with USB3.0 Intarface-Card. I connected one of PSEye to USB3.0 port. Then Device Manager only show as [Renesas Electronics USB 2.0 Hub] . To use the PSEye with USB3.0 What should I do? Here is specification of my recording PC. ------------------------------------------ CPU : Intel Core i7-870 M/B : GIGABYTE GA-H57M-USB3 (H57) MEM : DDR3-1333-2GB x2 (4GB) VGA : GeForce8600G HDD : SATA-500GB O S : Windows XP pro USB3.0 : NEC USB3.0 chipset (M/B Onboard) iPi Recorder : Ver. 1.4.0.75 ------------------------------------------ The USB3.0 driver version is "2.0.30.0". Device Manager show as [Renesas Electronics USB 3.0 Host Controller] and [Renesas Electronics USB 3.0 Root Hub] |
| Author: | Greenlaw [ Tue Feb 15, 2011 9:29 am ] |
| Post subject: | Re: I can't use PSEye with USB3.0 |
I can get the PS3 cameras to work with my USB 3.0 card. Sorry this isn't much help but just so you know, it should work. G. |
| Author: | Greenlaw [ Tue Feb 15, 2011 1:44 pm ] |
Hi, I just want to be sure I understand you. Are you saying the PS3 camera isn't working at all with this card, or is it that it shows up as a USB 2.0 device in Device Manager? If it's the latter, then I believe that's normal; you may only see USB 3.0 when you plug-in an actual USB 3.0 device. Just to be sure, I'll check my system at home tonight and let you know what I see. G. |
| Author: | nagahata [ Tue Feb 15, 2011 7:30 pm ] |
Greenlaw wrote: I just want to be sure I understand you. Are you saying the PS3 camera isn't working at all with this card, or is it that it shows up as a USB 2.0 device in Device Manager? Unfortunately, it is the former :( PSEye isn't work on any USB3.0 ports. PSEye not appear as a camera. Without knowing why appears as "Renesas Electronics USB 2.0 Hub" in Device Manager. However, I can use PSEye when connect it to USB2.0 card(VIA VT6214L) . And I can see "ipi winUSB Dirver for PlayStation3 Eye Camera" in Device Manager. hmm,,, |
| Author: | Greenlaw [ Tue Feb 15, 2011 11:16 pm ] |
Somebody posted a similar problem a few weeks ago. Maybe this will help? ipiRecorder not finding sony eye cams Good luck! G. |
| Author: | nagahata [ Wed Feb 16, 2011 2:06 am ] |
Hi there, and thank you for reply Greenlaw. Finally I solved this problem. It became a conclusion that the cause was a Model Number of PSEye. It was "SLEH-00201 (USB Camera-B3.04.06.1)" that I bought first. I got PSEye of another model number. That Model Number is "SLEH-00448 (USB Camera-B4.09.24.1)". Then, I got a "ipi winUSB Dirver for PlayStation3 Eye Camera" with USB3.0 in Device Manager. Whether this is a peculiar problem to Japan is not understood. I think that this information becomes everyone's help. I'll post here if I got anything else. Thanks, ありがとう
