 Post subject: cannot start application
PostPosted: Thu Aug 13, 2009 7:09 am
Every time i start ipi recorder (the latest version) i get an error that says: "cannot continue. the application is improperly formatted. contact the application vendor for assistance."
the program will only start and run when connected to the Internet. otherwise, i get the error. this is problematic as my recording room is out of the buildings wifi range. I've re-installed the application many times but the problem still persists.
The details on the error are:
PLATFORM VERSION INFO
Windows : 5.1.2600.196608 (Win32NT)
Common Language Runtime : 2.0.50727.3053
System.Deployment.dll : 2.0.50727.3053 (netfxsp.050727-3000)
mscorwks.dll : 2.0.50727.3053 (netfxsp.050727-3000)
dfdll.dll : 2.0.50727.3053 (netfxsp.050727-3000)
dfshim.dll : 2.0.50727.3053 (netfxsp.050727-3000)
SOURCES
Deployment url : file:///C:/Documents%20and%20Settings/Administrator/Desktop/iPi%20Recorder.appref-ms%7C
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of C:\Documents and Settings\Administrator\Desktop\iPi Recorder.appref-ms| resulted in exception. Following failure messages were detected:
+ Exception reading manifest from https://securelogin.arubanetworks.com/u ... pplication: the manifest may not be valid or the file could not be opened.
+ The 'INPUT' start tag on line 37 does not match the end tag of 'FORM'. Line 40, position 3.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
There were no warnings during this operation.
OPERATION PROGRESS STATUS
* [8/12/2009 9:47:18 PM] : Activation of C:\Documents and Settings\Administrator\Desktop\iPi Recorder.appref-ms| has started.
* [8/12/2009 9:47:18 PM] : Performing necessary update check as specified by the deployment.
ERROR DETAILS
Following errors were detected during this operation.
* [8/12/2009 9:47:19 PM] System.Deployment.Application.InvalidDeploymentException (ManifestParse)
- Exception reading manifest from https://securelogin.arubanetworks.com/u ... pplication: the manifest may not be valid or the file could not be opened.
- Source: System.Deployment
- Stack trace:
at System.Deployment.Application.ManifestReader.FromDocument(String localPath, ManifestType manifestType, Uri sourceUri)
at System.Deployment.Application.DownloadManager.DownloadManifest(Uri& sourceUri, String targetPath, IDownloadNotification notification, DownloadOptions options, ManifestType manifestType, ServerInformation& serverInformation)
at System.Deployment.Application.DownloadManager.DownloadDeploymentManifestDirect(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, IDownloadNotification notification, DownloadOptions options, ServerInformation& serverInformation)
at System.Deployment.Application.DownloadManager.DownloadDeploymentManifest(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentUpdate(SubscriptionState& subState, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator.ProcessOrFollowShortcut(String shortcutFile, String& errorPageUrl, TempFile& deployFile)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
--- Inner Exception ---
System.Xml.XmlException
- The 'INPUT' start tag on line 37 does not match the end tag of 'FORM'. Line 40, position 3.
- Source: System.Xml
- Stack trace:
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args)
at System.Xml.XmlTextReaderImpl.ThrowTagMismatch(NodeData startTag)
at System.Xml.XmlTextReaderImpl.ParseEndElement()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlTextReader.Read()
at System.Deployment.Application.ManifestValidatingReader.XmlFilteredReader.Read()
at System.Xml.XmlTextReaderImpl.Skip()
at System.Xml.XmlTextReader.Skip()
at System.Xml.XmlCharCheckingReader.Read()
at System.Xml.XsdValidatingReader.Read()
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
PostPosted: Thu Aug 13, 2009 8:27 am
It looks like iPi Recorder is installed through some kind of HTTP proxy, or installed on network drive. The manifest reference in your error report -
- looks very strange. It should be a direct reference, e.g.
http://www.ipisoft.com/downloads/iPiRec ... pplication, Culture=neutral, PublicKeyToken=b289d4e5f22ac95d, processorArchitecture=x86
I am a bit puzzled as Recorder installer does not have any options and I do not understand how you managed to install it that way. I think this can be caused by specific setup of your internet provider.
I recommend that you uninstall iPi Recorder, unplug your network connection and then reinstall iPi Recorder. Normally you should install recorder while being connected to internet to ensure proper installation of latest .NET Framework updates. But since you already have all latest .NET Framework updates installed you may do this trick with unplugged Recorder installation.
It is also possible that you were using an old version of iPi Recorder (1.0.0.x) and then switched to latest version. In that case, uninstalling Recorder, rebooting, and installing latest version may fix the problem.
Users browsing this forum: No registered users and 186 guests
