Blender Export
https://forum.ipisoft.com/viewtopic.php?f=5&t=5482
Author:  atmuc [ Wed Nov 02, 2011 2:08 am ]
Post subject:  Blender Export
exported rig has z-up problem. i have to rotate it.
also foot is not parallel to floor.
Author:  mrbones [ Thu Nov 03, 2011 2:45 pm ]
Post subject:  Re: Blender Export
Yes for blender I have seen this..Looks like a funny rotation bug.
Author:  mrbones [ Sat Dec 24, 2011 1:02 pm ]
Is this still a bug? Has it been dealt with?
Author:  demarii [ Thu Mar 15, 2012 8:45 am ]
The export seems geared for the old version of Blender 2.49b, the new versions of Blender 2.6+ import bvh by default expects the rig to be -Z Forward, Y Yp, but you can change this to Y forward Z Up in the import settings. The only bad thing about this method is if you prefer to do some clean-up in bvhacker then your figure is half in the floor and editing work is a bit more of a pain you have to turn off the ground plane and get funky with the camera, but re-orienting into Blender in the new version is not very difficult.
It would be great to have the choice between exporting the Blender Figure in 2.49b orientation or 2.6+
I'd honestly like to work with my custom rig, but sadly when you go into edit mode the rig completely loses its orientation.
Author:  a_haouchar [ Sat Apr 28, 2012 6:01 pm ]
Can someone assist me with Blender? When ever i import my file to blender and try and bind it to my rig, its totally stuffed.
Here is a screengrab:
The upper body is fine, but the lower body is the opposite direction and when i go to try and use the Fix twist button,nothing changes
Any help or support would be appreciated.
Author:  nestergal [ Thu May 03, 2012 11:54 am ]
To a_haouchar
I think the bone axes on your rig and on ipi-soft standard rig are different. Change bone axes in your rig (Crtl+R in edit mode)/
Author:  a_haouchar [ Mon May 14, 2012 1:17 am ]
Thanks but i tried that.Changes but still bad
