usb cable extension- What kind is best to get for Kinect ?
https://forum.ipisoft.com/viewtopic.php?f=5&t=5739
Author:  Castortroy2009 [ Mon Jan 02, 2012 6:28 pm ]
Post subject:  usb cable extension- What kind is best to get for Kinect ?
When I use the usb cables I have to move the Kinect devise far back as possible the kinect doesn't work.
IS there a special kind of cable to get?
Can I use a powered USB hub and a very long extension for a printer with the square end on the other side ?
Author:  niosop [ Mon Jan 02, 2012 10:25 pm ]
Post subject:  Re: usb cable extension- What kind is best to get for Kinect ?
You'll need an active usb extender. The passive ones are just extension cables and the signal becomes unusable after a certain distance. The active ones boost the signal. You could probably use a powered USB hub as an extender. If you have one, let us know how it works. If not, powered extenders are fairly cheap, there's a link to one on newegg in one of the recent posts.
EDIT: Here's the link to the post: viewtopic.php?f=2&t=5704
