| iPi Recorder won't even install https://forum.ipisoft.com/viewtopic.php?f=5&t=5759 |
Page 1 of 1 |
| Author: | Hiralis [ Fri Jan 13, 2012 6:09 am ] |
| Post subject: | iPi Recorder won't even install |
Okay, I have downloaded and installed iPi Studio and Calibrator, I have everything running smoothly except for the Recorder. It doesn't even install. Code: PLATFORM VERSION INFO Windows : 6.1.7601.65536 (Win32NT) Common Language Runtime : 4.0.30319.239 System.Deployment.dll : 4.0.30319.1 (RTMRel.030319-0100) clr.dll : 4.0.30319.239 (RTMGDR.030319-2300) dfdll.dll : 4.0.30319.1 (RTMRel.030319-0100) dfshim.dll : 4.0.31106.0 (Main.031106-0000) SOURCES Deployment url : file:///C:/Users/Guy%20Schulz/Mocap/iPiRecorder/iPiRecorder.application Deployment Provider url : http://www.ipisoft.com/downloads/iPiRecorder/iPiRecorder.application Server : Apache ERROR SUMMARY Below is a summary of the errors, details of these errors are listed later in the log. * Activation of C:\Users\Guy Schulz\Mocap\iPiRecorder\iPiRecorder.application resulted in exception. Following failure messages were detected: + The deployment identity at the deployment provider is not the same as the original deployment identity. COMPONENT STORE TRANSACTION FAILURE SUMMARY No transaction error was detected. WARNINGS There were no warnings during this operation. OPERATION PROGRESS STATUS * [13/01/2012 11:08:45 PM] : Activation of C:\Users\Guy Schulz\Mocap\iPiRecorder\iPiRecorder.application has started. ERROR DETAILS Following errors were detected during this operation. * [13/01/2012 11:08:46 PM] System.Deployment.Application.InvalidDeploymentException (SubscriptionSemanticValidation) - The deployment identity at the deployment provider is not the same as the original deployment identity. - Source: System.Deployment - Stack trace: at System.Deployment.Application.DownloadManager.FollowDeploymentProviderUri(SubscriptionStore subStore, AssemblyManifest& deployment, Uri& sourceUri, TempFile& tempFile, IDownloadNotification notification, DownloadOptions options) at System.Deployment.Application.DownloadManager.DownloadDeploymentManifestBypass(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, SubscriptionState& subState, IDownloadNotification notification, DownloadOptions options) at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl) at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state) COMPONENT STORE TRANSACTION DETAILS No transaction information is available. There are* the details on why the application can't be started. |
| Author: | Patrick [ Fri Jan 13, 2012 1:12 pm ] |
| Post subject: | Re: iPi Recorder won't even install |
I would confirm that no pieces of iPi Recorder got installed, delete your Recorder install exe, re-download the Recorder install file, and try to install again. After googling the error I'm not sure how much you could do to solve the problem. If that doesn't work I'd try turning UAC off (depending on Windows version) while installing, as it loves to cause problems when installing stuff. Hopefully this gets you started troubleshooting the issue, and gives the iPi guys some time to respond to your question. Patrick |
