| insufficient bandwidth https://forum.ipisoft.com/viewtopic.php?f=5&t=6359 |
Page 1 of 1 |
| Author: | siragin [ Mon Oct 15, 2012 5:54 pm ] |
| Post subject: | insufficient bandwidth |
Hello, I'm new to the ipisoft motion capture. I downloaded the trial and I am trying to use two kinects to my computer but the camera driver will not install correctly when I have both kinects plugged into the laptop and I get a message that I do not have insufficient bandwidth. What can I do to get both to work at the same time? |
| Author: | vmaslov [ Wed Oct 17, 2012 12:10 am ] |
| Post subject: | Re: insufficient bandwidth |
Hello It's a common problem with laptops. The thing is each Kinect should be connected to a separate USB controller. Often in laptops all available USB ports are linked with the same controller, and another is used for internal components like docking station connector. Try all possible USB ports combinations. If this does not work, then you'll need an external ExpressCard USB controller similar to this one, if your laptop has the ExpressCard slot. If not, then I cannot propose any solution besides using another computer - either a laptop with an ExpressCard slot, or a desktop. |
