This sensor is not genuine
https://forum.ipisoft.com/viewtopic.php?f=5&t=6642
Author:  khatarat [ Tue Dec 18, 2012 3:15 am ]
Post subject:  This sensor is not genuine
hi
why when i attach my kinects to PC IpiRecorder shows this error: This sensor is not genuine
i used xbox kinect. where is the problem and how can i solve it?
Author:  vmaslov [ Tue Dec 18, 2012 3:58 am ]
Post subject:  Re: This sensor is not genuine
Probably you've installed Kinect Runtime, not SDK. Kinect Runtime does not support Kinect for XBOX.
Please download and install Kinect SDK 1.6 from this link:
http://go.microsoft.com/fwlink/?LinkID=262831
Author:  khatarat [ Tue Dec 18, 2012 11:27 pm ]
i've installed Kinect SDk.is there any other Idea?
Author:  andrew [ Mon Dec 24, 2012 10:43 am ]
Hello!
If you still have this issue, please provide us with the following screenshots:
  • Device Manager with expanded node Microsoft Kinect when Kinect device is plugged to the computer
  • list of installed programs (Control Panel -> Add/Remove Programs) around item Kinect for Windows SDK 1.6
Author:  allen05 [ Sun Jan 27, 2013 10:20 pm ]
Post subject:  Error connecting Kinects to PC
hi
Author:  vmaslov [ Mon Jan 28, 2013 2:12 am ]
If you are not a spammer, follow the instructions from the previous post.
Author:  dpolcino [ Sun Sep 01, 2013 9:16 pm ]
I'm getting this intermittently as well. When I installed the newest iPi Recorder, did it install the wrong SDK or is the installer smart enough to know I'm using two Xbox Kinects? Like I said it'll work for a while, then bring up the "not official" warning.
Author:  orion_uk [ Tue Mar 31, 2015 6:42 am ]
OK, so just started getting this issue myself :(
Same situation as the others and the above recommendations don't resolve the issue for me, any other ideas please?
Thank you :)
File comment: Kinect in Device manager
File comment: not genuine error image
File comment: dll error screen cap image
Author:  orion_uk [ Tue Mar 31, 2015 7:05 am ]
dev kit wont install after SDK install completes :(
It was all working fine last time i shut down the computer!
gggrrrr!
File comment: installed Kinect related programs
File comment: dev kit wont install after SDK install completes
dev kit wont install after SDK install completes.PNG [ 23.99 KiB | Viewed 32064 times ]
Author:  vmaslov [ Tue Mar 31, 2015 8:36 am ]
I see that you have PrimeSense drivers for Kinect installed as well. It is very likely that there's a conflict between Kinect SDK drivers and those ones. Try uninstalling one of them.
Regarding installing the developer kit.
List of programs shows that you already have Kinect SDK and Kinect Developer Kit v1.8. And what fails to install is Kinect Developer Kit v1.6 - the wrong version. You should download v1.8 if you want to repair installation.
In any case, I don't recommend you to fall back to an older version of Kinect SDK.
