I've been trying to test out the dual kinect setup, but so far I have been unable to get the cameras to show up right in iPiRecorder.
With just one camera, the depth screen is a solid yellow, and while the normal camera will work at first, it will eventually freeze. Once it freezes, it refuses to even show that much upon reopening the program - it says that the sensor is in use by another application. Even unplugging and replugging in the sensor won't make this message go away - I have to plug it into a different USB to get it back to "normal." With two, both have the yellow screen problem, with only one normal camera showing up (the other being a black screen). Eventually, the same thing happens as detailed above. Additionally, it will sometimes give me a bandwidth error when trying to connect both at once, despite the fact that I think it shouldn't be a problem. (And, even if it is, I'm confused as to why it won't even work with just one.) The second "Kinect for Windows Camera" driver has also failed to install correctly.
I have similar problems when using a different computer as well. Both kinects are Kinect for Xbox The computer I am currently troubleshooting with is an ASUS Notebook G72GX Series running Windows 7 64-bit.
Help would be appreciated. Attached are images that may be helpful.
| Attachments: |
