No kinect device load at IPIrecorder start
https://forum.ipisoft.com/viewtopic.php?f=5&t=6762
Author:  diez54 [ Sun Jan 27, 2013 9:55 am ]
Post subject:  No kinect device load at IPIrecorder start
I'm try to test ipimocap software, but I can't load kinect device at startup.
I'm on macbookpro over bootcamp ( no probleme with other software kinect/mocap/scan ...) and use an xbox kinect.
In tool setting all driver for kinect is load ...
I've only "FaceTIme HD camera build"( intern camera of macbookpro) appear at start of ipirecorder ....
I don't find any issue , I test to removed all kinect , openNi , primsens driver, re-install all ......
Help needed.
I attache showl trace file
thx.
Diez
www.paradigme.tv
bug_kinect_not_appear_diez.gz [2.92 KiB]
Downloaded 732 times
Author:  andrew [ Mon Jan 28, 2013 10:26 am ]
Post subject:  Re: No kinect device load at IPIrecorder start
Hello!
Could you please try the following:
1. Make sure that AC/DC adapter is connected
2. Try different USB ports on your laptop
3. Re-install Kinect SDK from the following link:
http://www.microsoft.com/en-us/kinectforwindows/develop/developer-downloads.aspx
(Download Latest SDK button)
4. If you're here and still have no success then please provide us with screenshot of Control Panel (can be called right from iPi Recorder using corresponding item in tool menu) with expanded node Microsoft Kinect:
(Microsoft Kinect for XBOX devices should be connected to the computer at the screenshot moment)
