It is currently Tue Oct 27, 2026 3:49 am
 Post subject: menu/dialog issuses
PostPosted: Mon May 06, 2013 7:40 am
I have downloaded the trial and installed it. I can capture data and send it from the recorder to the editor using the send feature. The recording app works fine, no issues there.
When I use the editor I can use most of the features but none of the open, save, import or export menu items work. When I click any of these, the apps frame flashes like it's recognizing the command but the window/dialog never appears.
I've tried reinstalling, installing and running in admin mode and making a new user account and installing under that. Same results for each.
Any ideas?
 Post subject: Re: menu/dialog issuses
PostPosted: Mon May 06, 2013 8:18 am
Look like the problem described in another topic:
http://forum.ipisoft.com/viewtopic.php?f=5&t=3985
Try suggested there solution with running 2 instances of iPi Mocap Studio. I know, it is not convenient, but at least might be a workaround for a while.
Unfortunately, it is a rare issue among our users we could not reproduce yet. So there is no guarantee it will be fixed soon :(
PostPosted: Mon May 06, 2013 1:49 pm
I tried running 2 instances with the same result. We will look for another mocap option.
Thanks for the input and quick reply.
Users browsing this forum: No registered users and 39 guests
