PostPosted: Mon Mar 25, 2013 5:55 am
I just tried to do a calibration with the new studio version 2.3.0.148 using a file with works in version 2.3.0.146.
The video is at first not displayed in studio, when using the slider the video is displayed very very slow, calibration does not work.
Thank You very much!
Christoph
PostPosted: Mon Mar 25, 2013 6:13 am
Were there recently any updates related to your video card or video drivers?
Or maybe you are running 2.3.0.148 on a different PC?
Can you provide the iPiVideo file that causes the issue?
PostPosted: Mon Mar 25, 2013 6:46 am
while I was looking for a short file to send to You, the problem was solved !
After opening the studio I noticed that the left side of the video window touched the main windows frame and it looked like the position of the video
window changes on each redraw by 1(?) pixel, so the video window flickered left-right.
After resizing the main window the problem disappeared and i cannot reproduce it.
I have to mention, that I'm updated a licensed version of the program on one PC (Windows 8 64-Bit Geforce 680) and an expired trial on an other PC (Windows 8 64-Bit Geforce 660). The problem occured after the update on both machines, screen resolution 1920 * 1080 with different VNidia drivers. There were no hardware changes.
Thank You
Christoph
PostPosted: Mon Mar 25, 2013 6:56 am
Confirm, there is a viewport resizing issue we are aware of. Unfortunately, we could not yet find its cause. And only have released window size restoring feature as a workaround - so at least you don't need to resize window each time to get rid of this annoyance. Here is another topic about this issue:
http://forum.ipisoft.com/viewtopic.php?f=5&t=6754
