It is currently Tue Oct 27, 2026 4:21 am
 Post subject: Spine issues again
PostPosted: Sun May 05, 2013 10:27 pm
It's been a while since I commented on the spine issue but today I may have something new to report on the subject.
When tracking, I'm still seeing that 'side-bending spine' issue--in truth, it never really went completely away, even with the return of the 'Stiff Lower Spine' method. Previously, this was mostly noticeable when seated or when crouching but I'm seeing it even when standing erect. It's much better now but it's still a problem.
The real cause of this problem appears to be the difference between my actual body proportions vs the ideal iPi Actor rig. When I use my actual height or slightly shorter for the Actor, the spine gets compressed and bends slightly to one side or the other, or it causes the hips to sway strangely to one side. If I reduce the skeleton's height further so that the spine can straighten out inside the volume, then the feet will lift off the ground and they may wiggle around because now there is no longer contact with the floor. With the rigid actor proportions we are currently limited to, I'm having to accept that it's impossible for me to set an ideal height for the Actor in iPi Mocap Studio. This is frustrating because I know the software is fully capable of tracking better results.
I understand that you guys are not planning to release a fully customizable Actor until version 3.0, but I'm still hopeful that you will release a slightly more configurable skeleton for 2.0. It would help me immensely on our current production if I could just resize the spine and/or the legs slightly to better reflect my true body proportions.
Thanks for listening.
 Post subject: Re: Spine issues again
PostPosted: Sun May 05, 2013 11:22 pm
I experimented with another pair of shoes. This time I tried hiking shoes that add about 1.5 inches (3.81 cm) to my height, and the spine-bending error now appears to be corrected.
I think this illustrates my point. If I could just reduce the Actor's leg length by 1 to 1.5 inches or increase the spine length slightly, this should solve the problem without having to artificially increase my height.
PostPosted: Wed May 08, 2013 5:14 am
I still struggle with this issue Greenlaw, hopefully 3.0 will have this ironed out.
PostPosted: Wed May 08, 2013 12:07 pm
Thanks for confirming. I was beginning to think I had wrong body proportions for a human. :)
Users browsing this forum: No registered users and 29 guests
