 Post subject: ipistudio just closes
PostPosted: Mon May 06, 2013 10:18 am
I downloaded ipistudio to try it out and when launched it pops up. I get a loading wheel and then it closes. I tried both the steam version and direct version from the website. Same result. I've been searching here for a possible solution but no idea why this is happening.
My event log has nothing in it. The install log says everything was installed correctly and I tried running in administrator as well as compatibility modes.
On another computer this runs just fine but it has a worse video card so it's over 14 seconds per frame. The recorder on the other hand works just fine on this computer.
Specs
Windows 7 Ultimate 64 Bit.
i7 2600 8 core CPU
Geforce 8800GT Videocard.
8GB ram.
2TB Hard Drive Space.
Install Log
2013-05-06 11:40:30 -------------------------------------------------------------------
2013-05-06 11:40:30 dotNetInstaller (DNI), version 2.2.718.0
2013-05-06 11:40:30 Copyright (c) DevAge, Vestris Inc. & Contributors
2013-05-06 11:40:30 Operating system: Windows 7 SP1 (x64)
2013-05-06 11:40:30 Sequence: install
2013-05-06 11:40:30 UI level: full
2013-05-06 11:40:30 Configuration language id: 1033
2013-05-06 11:40:30 -- Loading supported components (lcid=1033)
2013-05-06 11:40:30 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 11:40:30 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 11:40:30 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 11:40:30 --- Loaded 3 supported component(s)
2013-05-06 11:40:30 Checking whether registry value 'SOFTWARE\Microsoft\DirectX\Version' exists
2013-05-06 11:40:30 Registry value: 4.09.00.0904
2013-05-06 11:40:30 -- DirectX End-User Runtimes 9.0c (DirectX End-User Runtimes 9.0c): INSTALLED
2013-05-06 11:40:30 Checking whether registry value 'Software\Microsoft\NET Framework Setup\NDP\v3.5\Install' exists
2013-05-06 11:40:30 Registry value: 1
2013-05-06 11:40:30 Check value: 1
2013-05-06 11:40:30 -- Microsoft .NET Framework 3.5 SP1 (Microsoft .NET Framework 3.5 SP1): INSTALLED
2013-05-06 11:40:30 Checking whether registry value 'Software\Microsoft\XNA\Framework\v3.0\ProductVersion' exists
2013-05-06 11:40:30 Registry value: 3.0.11010.0
2013-05-06 11:40:30 -- Microsoft XNA Framework Redistributable 3.0 (Microsoft XNA Framework Redistributable 3.0): INSTALLED
2013-05-06 11:40:30 All required components installed: yes
2013-05-06 11:40:30 All optional components installed: yes
2013-05-06 11:40:30 -- Adding 'label' control, text='The following components should be installed to run iPi Mocap Studio:', font=MS Shell Dlg (11 pt.), left=15, top=95, width=590, height=20
2013-05-06 11:40:30 -- Adding 'label' control, text='(Note that for the installation of Microsoft .NET Framework 3.5 SP1 internet connection is required.)', font=MS Shell Dlg (9 pt.), left=15, top=115, width=590, height=20
2013-05-06 11:40:30 -- Adding 'label' control, text='For more information about iPi Mocap Studio installation please visit the following link:', font=MS Shell Dlg (9 pt.), left=15, top=355, width=590, height=20
2013-05-06 11:40:30 -- Adding 'hyperlink' control, uri=http://wiki.ipisoft.com/iPi_Mocap_Studio_Installation, text='http://wiki.ipisoft.com/iPi_Mocap_Studio_Installation', font=MS Shell Dlg (9 pt.), left=15, top=370, width=590, height=20
2013-05-06 11:40:30 Start: install
2013-05-06 11:40:30 --- Complete Command
2013-05-06 11:40:30 dotNetInstaller finished, return code: 0 (0x0)
2013-05-06 12:53:51 -------------------------------------------------------------------
2013-05-06 12:53:51 dotNetInstaller (DNI), version 2.2.718.0
2013-05-06 12:53:51 Copyright (c) DevAge, Vestris Inc. & Contributors
2013-05-06 12:53:51 Operating system: Windows 7 SP1 (x64)
2013-05-06 12:53:51 Sequence: install
2013-05-06 12:53:51 UI level: full
2013-05-06 12:53:51 Configuration language id: 1033
2013-05-06 12:53:51 -- Loading supported components (lcid=1033)
2013-05-06 12:53:51 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:53:51 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:53:51 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:53:51 -- iPi Mocap Studio 2.3.1.149 (display_name='iPi Mocap Studio 2.3.1.149', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:53:51 --- Loaded 4 supported component(s)
2013-05-06 12:53:51 Checking whether registry value 'SOFTWARE\Microsoft\DirectX\Version' exists
2013-05-06 12:53:51 Registry value: 4.09.00.0904
2013-05-06 12:53:51 -- DirectX End-User Runtimes 9.0c (DirectX End-User Runtimes 9.0c): INSTALLED
2013-05-06 12:53:51 Checking whether registry value 'Software\Microsoft\NET Framework Setup\NDP\v3.5\Install' exists
2013-05-06 12:53:51 Registry value: 1
2013-05-06 12:53:51 Check value: 1
2013-05-06 12:53:51 -- Microsoft .NET Framework 3.5 SP1 (Microsoft .NET Framework 3.5 SP1): INSTALLED
2013-05-06 12:53:51 Checking whether registry value 'Software\Microsoft\XNA\Framework\v3.0\ProductVersion' exists
2013-05-06 12:53:51 Registry value: 3.0.11010.0
2013-05-06 12:53:51 -- Microsoft XNA Framework Redistributable 3.0 (Microsoft XNA Framework Redistributable 3.0): INSTALLED
2013-05-06 12:53:51 Checking file: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\iPiMocapStudio.application
2013-05-06 12:53:51 -- iPi Mocap Studio 2.3.1.149 (iPi Mocap Studio 2.3.1.149): NOT INSTALLED
2013-05-06 12:53:51 All required components installed: no
2013-05-06 12:53:51 All optional components installed: yes
2013-05-06 12:53:51 -- Adding 'license' control, text='I have read and accepted the license agreement', font=MS Shell Dlg (10 pt.), left=15, top=315, width=400, height=25
2013-05-06 12:53:51 Extracting license 'RES_LICENSE' to C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}_EULA.html
2013-05-06 12:53:51 -- Adding 'label' control, text='The following components should be installed to run iPi Mocap Studio:', font=MS Shell Dlg (11 pt.), left=15, top=95, width=590, height=20
2013-05-06 12:53:51 -- Adding 'label' control, text='(Note that for the installation of Microsoft .NET Framework 3.5 SP1 internet connection is required.)', font=MS Shell Dlg (9 pt.), left=15, top=115, width=590, height=20
2013-05-06 12:53:51 -- Adding 'label' control, text='For more information about iPi Mocap Studio installation please visit the following link:', font=MS Shell Dlg (9 pt.), left=15, top=355, width=590, height=20
2013-05-06 12:53:51 -- Adding 'hyperlink' control, uri=http://wiki.ipisoft.com/iPi_Mocap_Studio_Installation, text='http://wiki.ipisoft.com/iPi_Mocap_Studio_Installation', font=MS Shell Dlg (9 pt.), left=15, top=370, width=590, height=20
2013-05-06 12:53:51 Start: install
2013-05-06 12:53:58 -- Loading supported components (lcid=1033)
2013-05-06 12:53:58 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:53:58 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:53:58 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:53:58 -- iPi Mocap Studio 2.3.1.149 (display_name='iPi Mocap Studio 2.3.1.149', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:53:58 --- Loaded 4 supported component(s)
2013-05-06 12:53:58 --- Setting user-defined value 'RES_LICENSE'=1
2013-05-06 12:53:58 Extracting embedded files for component '*': NO FILES EMBEDDED
2013-05-06 12:53:58 --- Component 'DirectX End-User Runtimes 9.0c' (DirectX End-User Runtimes 9.0c): SKIPPED
2013-05-06 12:53:58 --- Component 'Microsoft .NET Framework 3.5 SP1' (Microsoft .NET Framework 3.5 SP1): SKIPPED
2013-05-06 12:53:58 --- Component 'Microsoft XNA Framework Redistributable 3.0' (Microsoft XNA Framework Redistributable 3.0): SKIPPED
2013-05-06 12:53:58 --- Component 'iPi Mocap Studio 2.3.1.149' (iPi Mocap Studio 2.3.1.149): EXECUTING
2013-05-06 12:53:58 Extracting embedded files for component 'iPi Mocap Studio 2.3.1.149': 1 CAB(s)
2013-05-06 12:53:58 Resolved CAB path 'C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}' for component 'IPI_MOCAP_STUDIO_2_3_1_149'
2013-05-06 12:53:58 Extracting 'SETUP_IPI_MOCAP_STUDIO_2_3_1_149_1.CAB' for component 'IPI_MOCAP_STUDIO_2_3_1_149'
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\iPiMocapStudio.application
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\iPiMocapStudio.application
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\setup.exe
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\setup.exe
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\EULA.html.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\EULA.html.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiDepthSensorCalibration.dll.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiDepthSensorCalibration.dll.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiHelpers.dll.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiHelpers.dll.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiLib.Fbx.dll.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiLib.Fbx.dll.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMath.dll.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMath.dll.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.config.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.config.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.manifest
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.manifest
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiVideo.dll.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiVideo.dll.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiVideo.WpfTools.dll.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiVideo.WpfTools.dll.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\iPiStudio.ico.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\iPiStudio.ico.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\MoCapProj.ico.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\MoCapProj.ico.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\MoCapTrialProj.ico.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\MoCapTrialProj.ico.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\Keyboard Shortcuts.xps.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\Keyboard Shortcuts.xps.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\Release Notes.xps.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\Release Notes.xps.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Dual Depth Sensor Configuration.xps.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Dual Depth Sensor Configuration.xps.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Multiple PS Eye Cameras Configuration.xps.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Multiple PS Eye Cameras Configuration.xps.deploy
2013-05-06 12:53:58 Extracting: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Single Depth Sensor Configuration.xps.deploy
2013-05-06 12:53:58 Done: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Single Depth Sensor Configuration.xps.deploy
2013-05-06 12:53:59 -- Executable: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\setup.exe
2013-05-06 12:53:59 Executing: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\setup.exe
2013-05-06 12:54:01 --- Component 'iPi Mocap Studio 2.3.1.149 (iPi Mocap Studio 2.3.1.149): DIALOG CLOSED
2013-05-06 12:54:01 *** Component 'iPi Mocap Studio 2.3.1.149' (iPi Mocap Studio 2.3.1.149): SUCCESS
2013-05-06 12:54:01 -- Loading supported components (lcid=1033)
2013-05-06 12:54:01 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:01 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:01 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:01 -- iPi Mocap Studio 2.3.1.149 (display_name='iPi Mocap Studio 2.3.1.149', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:01 --- Loaded 4 supported component(s)
2013-05-06 12:54:01 Checking whether registry value 'SOFTWARE\Microsoft\DirectX\Version' exists
2013-05-06 12:54:01 Registry value: 4.09.00.0904
2013-05-06 12:54:01 -- DirectX End-User Runtimes 9.0c (DirectX End-User Runtimes 9.0c): INSTALLED
2013-05-06 12:54:01 Checking whether registry value 'Software\Microsoft\NET Framework Setup\NDP\v3.5\Install' exists
2013-05-06 12:54:01 Registry value: 1
2013-05-06 12:54:01 Check value: 1
2013-05-06 12:54:01 -- Microsoft .NET Framework 3.5 SP1 (Microsoft .NET Framework 3.5 SP1): INSTALLED
2013-05-06 12:54:01 Checking whether registry value 'Software\Microsoft\XNA\Framework\v3.0\ProductVersion' exists
2013-05-06 12:54:01 Registry value: 3.0.11010.0
2013-05-06 12:54:01 -- Microsoft XNA Framework Redistributable 3.0 (Microsoft XNA Framework Redistributable 3.0): INSTALLED
2013-05-06 12:54:01 Checking file: C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}\s\iPiMocapStudio.application
2013-05-06 12:54:01 -- iPi Mocap Studio 2.3.1.149 (iPi Mocap Studio 2.3.1.149): INSTALLED
2013-05-06 12:54:01 All required components installed: yes
2013-05-06 12:54:01 All optional components installed: yes
2013-05-06 12:54:01 --- Complete Command
2013-05-06 12:54:01 Deleting 'C:\Users\Justin\AppData\Local\Temp\{5F153677-E04E-4674-BA83-8C9C27B25FB3}_EULA.html'
2013-05-06 12:54:01 dotNetInstaller finished, return code: 0 (0x0)
2013-05-06 12:54:20 -------------------------------------------------------------------
2013-05-06 12:54:20 dotNetInstaller (DNI), version 2.2.718.0
2013-05-06 12:54:20 Copyright (c) DevAge, Vestris Inc. & Contributors
2013-05-06 12:54:20 Operating system: Windows 7 SP1 (x64)
2013-05-06 12:54:20 Sequence: install
2013-05-06 12:54:20 UI level: full
2013-05-06 12:54:20 Configuration language id: 1033
2013-05-06 12:54:20 -- Loading supported components (lcid=1033)
2013-05-06 12:54:20 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:20 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:20 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:20 -- iPi Mocap Studio 2.3.1.149 (display_name='iPi Mocap Studio 2.3.1.149', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:20 --- Loaded 4 supported component(s)
2013-05-06 12:54:20 Checking whether registry value 'SOFTWARE\Microsoft\DirectX\Version' exists
2013-05-06 12:54:20 Registry value: 4.09.00.0904
2013-05-06 12:54:20 -- DirectX End-User Runtimes 9.0c (DirectX End-User Runtimes 9.0c): INSTALLED
2013-05-06 12:54:20 Checking whether registry value 'Software\Microsoft\NET Framework Setup\NDP\v3.5\Install' exists
2013-05-06 12:54:20 Registry value: 1
2013-05-06 12:54:20 Check value: 1
2013-05-06 12:54:20 -- Microsoft .NET Framework 3.5 SP1 (Microsoft .NET Framework 3.5 SP1): INSTALLED
2013-05-06 12:54:20 Checking whether registry value 'Software\Microsoft\XNA\Framework\v3.0\ProductVersion' exists
2013-05-06 12:54:20 Registry value: 3.0.11010.0
2013-05-06 12:54:20 -- Microsoft XNA Framework Redistributable 3.0 (Microsoft XNA Framework Redistributable 3.0): INSTALLED
2013-05-06 12:54:20 Checking file: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\iPiMocapStudio.application
2013-05-06 12:54:20 -- iPi Mocap Studio 2.3.1.149 (iPi Mocap Studio 2.3.1.149): NOT INSTALLED
2013-05-06 12:54:20 All required components installed: no
2013-05-06 12:54:20 All optional components installed: yes
2013-05-06 12:54:20 -- Adding 'license' control, text='I have read and accepted the license agreement', font=MS Shell Dlg (10 pt.), left=15, top=315, width=400, height=25
2013-05-06 12:54:20 Extracting license 'RES_LICENSE' to C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}_EULA.html
2013-05-06 12:54:20 -- Adding 'label' control, text='The following components should be installed to run iPi Mocap Studio:', font=MS Shell Dlg (11 pt.), left=15, top=95, width=590, height=20
2013-05-06 12:54:20 -- Adding 'label' control, text='(Note that for the installation of Microsoft .NET Framework 3.5 SP1 internet connection is required.)', font=MS Shell Dlg (9 pt.), left=15, top=115, width=590, height=20
2013-05-06 12:54:20 -- Adding 'label' control, text='For more information about iPi Mocap Studio installation please visit the following link:', font=MS Shell Dlg (9 pt.), left=15, top=355, width=590, height=20
2013-05-06 12:54:20 -- Adding 'hyperlink' control, uri=http://wiki.ipisoft.com/iPi_Mocap_Studio_Installation, text='http://wiki.ipisoft.com/iPi_Mocap_Studio_Installation', font=MS Shell Dlg (9 pt.), left=15, top=370, width=590, height=20
2013-05-06 12:54:20 Start: install
2013-05-06 12:54:23 -- Loading supported components (lcid=1033)
2013-05-06 12:54:23 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:23 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:23 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:23 -- iPi Mocap Studio 2.3.1.149 (display_name='iPi Mocap Studio 2.3.1.149', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:23 --- Loaded 4 supported component(s)
2013-05-06 12:54:23 --- Setting user-defined value 'RES_LICENSE'=1
2013-05-06 12:54:23 Extracting embedded files for component '*': NO FILES EMBEDDED
2013-05-06 12:54:23 --- Component 'DirectX End-User Runtimes 9.0c' (DirectX End-User Runtimes 9.0c): SKIPPED
2013-05-06 12:54:23 --- Component 'Microsoft .NET Framework 3.5 SP1' (Microsoft .NET Framework 3.5 SP1): SKIPPED
2013-05-06 12:54:23 --- Component 'Microsoft XNA Framework Redistributable 3.0' (Microsoft XNA Framework Redistributable 3.0): SKIPPED
2013-05-06 12:54:23 --- Component 'iPi Mocap Studio 2.3.1.149' (iPi Mocap Studio 2.3.1.149): EXECUTING
2013-05-06 12:54:23 Extracting embedded files for component 'iPi Mocap Studio 2.3.1.149': 1 CAB(s)
2013-05-06 12:54:23 Resolved CAB path 'C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}' for component 'IPI_MOCAP_STUDIO_2_3_1_149'
2013-05-06 12:54:23 Extracting 'SETUP_IPI_MOCAP_STUDIO_2_3_1_149_1.CAB' for component 'IPI_MOCAP_STUDIO_2_3_1_149'
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\iPiMocapStudio.application
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\iPiMocapStudio.application
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\setup.exe
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\setup.exe
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\EULA.html.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\EULA.html.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiDepthSensorCalibration.dll.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiDepthSensorCalibration.dll.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiHelpers.dll.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiHelpers.dll.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiLib.Fbx.dll.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiLib.Fbx.dll.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMath.dll.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMath.dll.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.config.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.config.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.manifest
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.manifest
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiVideo.dll.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiVideo.dll.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiVideo.WpfTools.dll.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiVideo.WpfTools.dll.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\iPiStudio.ico.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\iPiStudio.ico.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\MoCapProj.ico.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\MoCapProj.ico.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\MoCapTrialProj.ico.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\MoCapTrialProj.ico.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\Keyboard Shortcuts.xps.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\Keyboard Shortcuts.xps.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\Release Notes.xps.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\Release Notes.xps.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Dual Depth Sensor Configuration.xps.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Dual Depth Sensor Configuration.xps.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Multiple PS Eye Cameras Configuration.xps.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Multiple PS Eye Cameras Configuration.xps.deploy
2013-05-06 12:54:23 Extracting: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Single Depth Sensor Configuration.xps.deploy
2013-05-06 12:54:23 Done: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Single Depth Sensor Configuration.xps.deploy
2013-05-06 12:54:24 -- Executable: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\setup.exe
2013-05-06 12:54:24 Executing: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\setup.exe
2013-05-06 12:54:26 --- Component 'iPi Mocap Studio 2.3.1.149 (iPi Mocap Studio 2.3.1.149): DIALOG CLOSED
2013-05-06 12:54:26 *** Component 'iPi Mocap Studio 2.3.1.149' (iPi Mocap Studio 2.3.1.149): SUCCESS
2013-05-06 12:54:26 -- Loading supported components (lcid=1033)
2013-05-06 12:54:26 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:26 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:26 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:26 -- iPi Mocap Studio 2.3.1.149 (display_name='iPi Mocap Studio 2.3.1.149', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:54:26 --- Loaded 4 supported component(s)
2013-05-06 12:54:26 Checking whether registry value 'SOFTWARE\Microsoft\DirectX\Version' exists
2013-05-06 12:54:26 Registry value: 4.09.00.0904
2013-05-06 12:54:26 -- DirectX End-User Runtimes 9.0c (DirectX End-User Runtimes 9.0c): INSTALLED
2013-05-06 12:54:26 Checking whether registry value 'Software\Microsoft\NET Framework Setup\NDP\v3.5\Install' exists
2013-05-06 12:54:26 Registry value: 1
2013-05-06 12:54:26 Check value: 1
2013-05-06 12:54:26 -- Microsoft .NET Framework 3.5 SP1 (Microsoft .NET Framework 3.5 SP1): INSTALLED
2013-05-06 12:54:26 Checking whether registry value 'Software\Microsoft\XNA\Framework\v3.0\ProductVersion' exists
2013-05-06 12:54:26 Registry value: 3.0.11010.0
2013-05-06 12:54:26 -- Microsoft XNA Framework Redistributable 3.0 (Microsoft XNA Framework Redistributable 3.0): INSTALLED
2013-05-06 12:54:26 Checking file: C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}\s\iPiMocapStudio.application
2013-05-06 12:54:26 -- iPi Mocap Studio 2.3.1.149 (iPi Mocap Studio 2.3.1.149): INSTALLED
2013-05-06 12:54:26 All required components installed: yes
2013-05-06 12:54:26 All optional components installed: yes
2013-05-06 12:54:26 --- Complete Command
2013-05-06 12:54:26 Deleting 'C:\Users\Justin\AppData\Local\Temp\{48755CC3-C0B4-447F-AD47-0B43ECB55F65}_EULA.html'
2013-05-06 12:54:26 dotNetInstaller finished, return code: 0 (0x0)
2013-05-06 12:55:13 -------------------------------------------------------------------
2013-05-06 12:55:13 dotNetInstaller (DNI), version 2.2.718.0
2013-05-06 12:55:13 Copyright (c) DevAge, Vestris Inc. & Contributors
2013-05-06 12:55:13 Operating system: Windows 7 SP1 (x64)
2013-05-06 12:55:13 Sequence: install
2013-05-06 12:55:13 UI level: full
2013-05-06 12:55:13 Configuration language id: 1033
2013-05-06 12:55:13 -- Loading supported components (lcid=1033)
2013-05-06 12:55:13 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:55:13 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:55:13 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:55:13 -- iPi Mocap Studio 2.3.1.149 (display_name='iPi Mocap Studio 2.3.1.149', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:55:13 --- Loaded 4 supported component(s)
2013-05-06 12:55:13 Checking whether registry value 'SOFTWARE\Microsoft\DirectX\Version' exists
2013-05-06 12:55:13 Registry value: 4.09.00.0904
2013-05-06 12:55:13 -- DirectX End-User Runtimes 9.0c (DirectX End-User Runtimes 9.0c): INSTALLED
2013-05-06 12:55:13 Checking whether registry value 'Software\Microsoft\NET Framework Setup\NDP\v3.5\Install' exists
2013-05-06 12:55:13 Registry value: 1
2013-05-06 12:55:13 Check value: 1
2013-05-06 12:55:13 -- Microsoft .NET Framework 3.5 SP1 (Microsoft .NET Framework 3.5 SP1): INSTALLED
2013-05-06 12:55:13 Checking whether registry value 'Software\Microsoft\XNA\Framework\v3.0\ProductVersion' exists
2013-05-06 12:55:13 Registry value: 3.0.11010.0
2013-05-06 12:55:13 -- Microsoft XNA Framework Redistributable 3.0 (Microsoft XNA Framework Redistributable 3.0): INSTALLED
2013-05-06 12:55:13 Checking file: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\iPiMocapStudio.application
2013-05-06 12:55:13 -- iPi Mocap Studio 2.3.1.149 (iPi Mocap Studio 2.3.1.149): NOT INSTALLED
2013-05-06 12:55:13 All required components installed: no
2013-05-06 12:55:13 All optional components installed: yes
2013-05-06 12:55:13 -- Adding 'license' control, text='I have read and accepted the license agreement', font=MS Shell Dlg (10 pt.), left=15, top=315, width=400, height=25
2013-05-06 12:55:13 Extracting license 'RES_LICENSE' to C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}_EULA.html
2013-05-06 12:55:13 -- Adding 'label' control, text='The following components should be installed to run iPi Mocap Studio:', font=MS Shell Dlg (11 pt.), left=15, top=95, width=590, height=20
2013-05-06 12:55:13 -- Adding 'label' control, text='(Note that for the installation of Microsoft .NET Framework 3.5 SP1 internet connection is required.)', font=MS Shell Dlg (9 pt.), left=15, top=115, width=590, height=20
2013-05-06 12:55:13 -- Adding 'label' control, text='For more information about iPi Mocap Studio installation please visit the following link:', font=MS Shell Dlg (9 pt.), left=15, top=355, width=590, height=20
2013-05-06 12:55:13 -- Adding 'hyperlink' control, uri=http://wiki.ipisoft.com/iPi_Mocap_Studio_Installation, text='http://wiki.ipisoft.com/iPi_Mocap_Studio_Installation', font=MS Shell Dlg (9 pt.), left=15, top=370, width=590, height=20
2013-05-06 12:55:13 Start: install
2013-05-06 12:55:19 -- Loading supported components (lcid=1033)
2013-05-06 12:55:19 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:55:19 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:55:19 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:55:19 -- iPi Mocap Studio 2.3.1.149 (display_name='iPi Mocap Studio 2.3.1.149', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:55:19 --- Loaded 4 supported component(s)
2013-05-06 12:55:19 --- Setting user-defined value 'RES_LICENSE'=1
2013-05-06 12:55:19 Extracting embedded files for component '*': NO FILES EMBEDDED
2013-05-06 12:55:19 --- Component 'DirectX End-User Runtimes 9.0c' (DirectX End-User Runtimes 9.0c): SKIPPED
2013-05-06 12:55:19 --- Component 'Microsoft .NET Framework 3.5 SP1' (Microsoft .NET Framework 3.5 SP1): SKIPPED
2013-05-06 12:55:19 --- Component 'Microsoft XNA Framework Redistributable 3.0' (Microsoft XNA Framework Redistributable 3.0): SKIPPED
2013-05-06 12:55:19 --- Component 'iPi Mocap Studio 2.3.1.149' (iPi Mocap Studio 2.3.1.149): EXECUTING
2013-05-06 12:55:19 Extracting embedded files for component 'iPi Mocap Studio 2.3.1.149': 1 CAB(s)
2013-05-06 12:55:19 Resolved CAB path 'C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}' for component 'IPI_MOCAP_STUDIO_2_3_1_149'
2013-05-06 12:55:19 Extracting 'SETUP_IPI_MOCAP_STUDIO_2_3_1_149_1.CAB' for component 'IPI_MOCAP_STUDIO_2_3_1_149'
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\iPiMocapStudio.application
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\iPiMocapStudio.application
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\setup.exe
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\setup.exe
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\EULA.html.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\EULA.html.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiDepthSensorCalibration.dll.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiDepthSensorCalibration.dll.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiHelpers.dll.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiHelpers.dll.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiLib.Fbx.dll.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiLib.Fbx.dll.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMath.dll.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMath.dll.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.config.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.config.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.manifest
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiMocapStudio.exe.manifest
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiVideo.dll.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiVideo.dll.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiVideo.WpfTools.dll.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\iPiVideo.WpfTools.dll.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\iPiStudio.ico.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\iPiStudio.ico.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\MoCapProj.ico.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\MoCapProj.ico.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\MoCapTrialProj.ico.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Resources\MoCapTrialProj.ico.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\Keyboard Shortcuts.xps.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\Keyboard Shortcuts.xps.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\Release Notes.xps.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\Release Notes.xps.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Dual Depth Sensor Configuration.xps.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Dual Depth Sensor Configuration.xps.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Multiple PS Eye Cameras Configuration.xps.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Multiple PS Eye Cameras Configuration.xps.deploy
2013-05-06 12:55:19 Extracting: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Single Depth Sensor Configuration.xps.deploy
2013-05-06 12:55:19 Done: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\Application Files\iPiMocapStudio_2_3_1_149\Help\User Guide for Single Depth Sensor Configuration.xps.deploy
2013-05-06 12:55:20 -- Executable: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\setup.exe
2013-05-06 12:55:20 Executing: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\setup.exe
2013-05-06 12:55:21 --- Component 'iPi Mocap Studio 2.3.1.149 (iPi Mocap Studio 2.3.1.149): DIALOG CLOSED
2013-05-06 12:55:21 *** Component 'iPi Mocap Studio 2.3.1.149' (iPi Mocap Studio 2.3.1.149): SUCCESS
2013-05-06 12:55:21 -- Loading supported components (lcid=1033)
2013-05-06 12:55:21 -- DirectX End-User Runtimes 9.0c (display_name='DirectX End-User Runtimes 9.0c', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:55:21 -- Microsoft .NET Framework 3.5 SP1 (display_name='Microsoft .NET Framework 3.5 SP1', os_filter_lcid=, os_filter=, os_filter_min=Windows XP SP2, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:55:21 -- Microsoft XNA Framework Redistributable 3.0 (display_name='Microsoft XNA Framework Redistributable 3.0', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:55:21 -- iPi Mocap Studio 2.3.1.149 (display_name='iPi Mocap Studio 2.3.1.149', os_filter_lcid=, os_filter=, os_filter_min=, os_filter_max=, processor_architecture_filter=): LOADED
2013-05-06 12:55:21 --- Loaded 4 supported component(s)
2013-05-06 12:55:21 Checking whether registry value 'SOFTWARE\Microsoft\DirectX\Version' exists
2013-05-06 12:55:21 Registry value: 4.09.00.0904
2013-05-06 12:55:21 -- DirectX End-User Runtimes 9.0c (DirectX End-User Runtimes 9.0c): INSTALLED
2013-05-06 12:55:21 Checking whether registry value 'Software\Microsoft\NET Framework Setup\NDP\v3.5\Install' exists
2013-05-06 12:55:21 Registry value: 1
2013-05-06 12:55:21 Check value: 1
2013-05-06 12:55:21 -- Microsoft .NET Framework 3.5 SP1 (Microsoft .NET Framework 3.5 SP1): INSTALLED
2013-05-06 12:55:21 Checking whether registry value 'Software\Microsoft\XNA\Framework\v3.0\ProductVersion' exists
2013-05-06 12:55:21 Registry value: 3.0.11010.0
2013-05-06 12:55:21 -- Microsoft XNA Framework Redistributable 3.0 (Microsoft XNA Framework Redistributable 3.0): INSTALLED
2013-05-06 12:55:21 Checking file: C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}\s\iPiMocapStudio.application
2013-05-06 12:55:21 -- iPi Mocap Studio 2.3.1.149 (iPi Mocap Studio 2.3.1.149): INSTALLED
2013-05-06 12:55:21 All required components installed: yes
2013-05-06 12:55:21 All optional components installed: yes
2013-05-06 12:55:21 --- Complete Command
2013-05-06 12:55:21 Deleting 'C:\Users\Justin\AppData\Local\Temp\{3BFA65EE-FF69-4A0C-A200-6EA8C99349E8}_EULA.html'
2013-05-06 12:55:21 dotNetInstaller finished, return code: 0 (0x0)
PostPosted: Tue May 07, 2013 3:24 am
Are those specs for the computer that is able to run iPi Mocap Studio or the computer that can't run it? Just wondering. (I'm sure the developers are wondering too.)
Assuming that's the computer that can't run iPi Mocap Studio, even if it was running, I'm almost certain that tracking performance won't be much faster with a 8800GT. If the software runs better on the other computer, you might consider getting a better graphics card for it possible. Need more information for better suggestions but just a thought for now.
PostPosted: Tue May 07, 2013 4:39 am
It's very uncertain where to dig for the root of this issue.
Do you see only mouse cursor wheel before crash, or the tiny window with the wheel and "Initializing" message appears also? Maybe you could provide a screencast?
Do you have the latest drivers for video card?
PostPosted: Tue May 07, 2013 5:38 am
That's the specs for the computer that can't run it.
Latest supported video drivers are installed. All I see is this window appear for a fraction of a second and then close itself.
PostPosted: Tue May 07, 2013 7:49 am
Ah, okay. What I wrote last night may still stand.
I started out with a 8800 GT or something very similar to it years ago when I started beta testing iPi Mocap Studio and I have since upgraded my card at least twice. I think you will be disappointed with the performance of the 8800 GT because of the lack of a modern GPU architecture. iPi Mocap Studio's calculation of physics is highly dependent on the card's GPU capabilities.
PostPosted: Tue May 07, 2013 8:32 am
I plan on getting a 660 or 660 Ti but only if I can get the thing to start. I don't mind waiting a day to get an animation to test it out. The other system is just not in an appropriate area for it. I'm starting to see the massive disadvantages of a single depth sensor.
PostPosted: Tue May 07, 2013 8:50 am
I understand. I hope you can get it running soon.
Single Kinect can work quite well--a few shots in 'Happy Box' were recorded and tracked using the earliest implementation of single Kinect in iPi DMC 1.0--but, yes, there's a world of difference when you upgrade to dual Kinect. Even with a 90 degree setup, the dual configuration can record and track many 360 degree motions. I've been able to record some 360 motions with a single Kinect but only within strict limits.
PostPosted: Wed May 08, 2013 3:51 am
Does your PC have Intel integrated graphics enabled? If yes, try to disable it.
The problem may be also somewhere in OS environment. Can you move the system HDD from working PC to non-working and test, whether that installation of Windows works with this hardware? Or try clean Windows install, if there is such opportunity.
PostPosted: Wed May 08, 2013 1:59 pm
No integrated graphics enabled.
If I move the hard drive. My windows won't work properly because it's OEM windows That will make it invalid. I've done it in the past and it was a nightmare getting Microsoft to re enable it.
PostPosted: Mon May 13, 2013 2:37 am
Most probably, this issue is related to software environment - some other installed programs or OS settings. Unfortunately, it is hard to say what exactly. One of our users previously had the similar issue, and he only could solve this with Windows reinstall.
