It is currently Tue Oct 27, 2026 10:54 am
PostPosted: Tue May 07, 2013 9:18 am
I have a same problem with him viewtopic.php?f=5&t=6714
But I don't know how to solve
I have tried a lot of computers,Are all the same problem
I am in despair,help me please!!!!!!!!!!
PostPosted: Wed May 08, 2013 2:39 am
Have you tried different models of BT dongles?
You can also try to use MotioninJoy BT drivers. See instructions in our wiki:
http://wiki.ipisoft.com/Motion_in_Joy_Installation
PostPosted: Wed May 08, 2013 7:59 am
Still not success,ask a question,when"Choose matching options",I select"Do not use the code to match" Because it doesn't have a matching code,This is right?
PostPosted: Mon May 13, 2013 2:30 am
What are you talking about? The code that Windows asks when pairing BT device with the controller? If you are using either pairing procedure in iPi Recorder, or in MiJ DS3 Tool, the code is never asked for.
PostPosted: Mon May 13, 2013 3:23 am
Is your OS Windows 7 64-bit as in the post you've initially mentioned, or other version?
PostPosted: Wed May 15, 2013 6:43 pm
I mean when I add a Bluetooth adapter,window7 display"Choose matching options",I select"Do not use the code to match" Because it doesn't have a matching code!!
My ipi recorder2 Can't find the ps3 move,and "show trace":
15:17:43.830: Information: [Thread=13] iPiRecorder.PsMove.PairingProcedure: Trying to add device 00:18:00:2A:0D:B7 (Motion Controller)
15:17:58.832: Warning: Function BluetoothSetServiceState for device '00:18:00:2A:0D:B7 (Motion Controller)' returns 1060
15:17:58.833: Warning: [Thread=13] iPiRecorder.PsMove.PairingProcedure: Can't set HID service for device 00:18:00:2A:0D:B7 (Motion Controller)
15:17:58.835: Information: [Thread=13] iPiRecorder.PsMove.PairingProcedure: Device 00:18:00:2A:0D:B7 (Motion Controller) is not added: IsConnected=True, IsRembemered=False, IsHidServiceInstalled=False
Users browsing this forum: No registered users and 123 guests
