It is currently Wed Oct 28, 2026 5:38 pm
 Post subject: Ground question
PostPosted: Sat Jun 08, 2013 9:03 am
How do you adjust the orientation of the grid?
 Post subject: Re: Ground question
PostPosted: Sat Jun 08, 2013 9:07 am
Why is disconnected, I can adjust the display from you?
PostPosted: Sat Jun 08, 2013 9:24 am
It is not necessary at all. However, if you feel more comfortable with proper alignment of grid with walls or objects on the floor, you can rotate the actor's model around vertical axis and hit the "Recenter coordinate system on character" button at the "Scene" tab.
This should not bother you. The grid is just clipped by video image rectangle which is automatically positioned so that the actor's model is fully visible.
PostPosted: Sun Jun 09, 2013 6:38 am
ok ,thank you
Users browsing this forum: No registered users and 34 guests
